Question about Car Audio & Video
Where is the audio ic at on a jenson Kdc 9640 car stereo
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: Pioneer car stereo output Ic's
In most cases the problem is the electronic volume IC, ref # IC151 and part number PLM003AM (in the DEH-1600). It is a different part number and ref # in other models.
It is not always this part that causes the failure, sometimes it can be the muting transistor, a voltage regulator or even the micro on more rare occasions. It will require some troubleshooting to figure out exactly what part it needs. You will need to have an O-scope to trace down the audio signal and follow it from one pin to another. You also need a multimeter to check a few voltages in the radio. All of this must be done on a test bench with the radio powered on with a power supply. If you do not have these tools, you will not be able to figure it out for certain, you would only be taking a stab in the dark. That can get rather frustrating and even expensive buying parts that do not fix the problem.
The electronic volume IC is a flat pack surface mounted component and requires the very best soldering skills to be able to replace. It is very easy to do damage to the circuit board that can not be repaired if it is not done perfectly. If you have not replaced these type of components before, you should not even attempt this repair.
If you would like the service manual I can sell you the PDF format of it for $10. I also have the service manuals for most Pioneer products as well as Kenwoods, JVC, Panasonic, Denon, Marantz, Clarion, and more. Let me know if you would like to get it. The service manual is very helpful in repairing electronics. It contains the schematics and parts list which is vital to make sure you get the right parts and to be able to trace down any signals and to know what parts are doing wha, and to figuring out if the voltages are correct.
I hope this helps,
Dave
I hope this helps
Posted on Nov 18, 2008
SOURCE: KDC-9640 wont play
SINCE YOUR JENSEN ISNT WORKING HOW ABOUT YOU SEND ME THE POWER PLUG OR MAYBE SOME ADVICE WHERE I CAN GET ONE????????
Posted on Feb 12, 2010
  • 4844 Answers
SOURCE: i need unlock code for my kdc-mp2035 kenwood stereo
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Posted on Jul 06, 2010
kenw392
  • 2226 Answers
SOURCE: I have a Kenwood car
The output ic is a TDA7560A. You can get it at pacparts.com.
Posted on Mar 24, 2011
My stereo have a problem when i am opening it the screen appear protect how an i solve ghe problem of that stereo
First, if you can, check your speakers and speaker wires for shorts and/or grounds. If they check out fine, press the reset switch, it should be a small indentation about the size of a pencil tip and will not be marked. If that doesn't work, you may have a bad output ic.
Oct 08, 2011 | Kenwood KDC-MP235 CD Player
All of the sudden my stereo locked up and says protect can't get it to turn off.
try checking your speaker wires and speakers for shorts or grounds. you may also have a bad output ic inside of the deck itself.
Jan 17, 2011 | Kenwood Kdc-mp345u Car CD / USB Player
I was installing it and it burned can it be fixed
Not really.It probably fried the either IC board or IVR.It would be much cheaper to buy another one and pay professional to install it.
Jan 05, 2010 | Kenwood KDC-138 FM / AM Receiver
On my kenwood kdc mp438u i tried everything it said to do but it keep saying protect
Could be a short circuit on your speaker output, try disconnecting all 4 speaker wires and then power up. Otherwise its the audio amplifier circuit that needs to be replaced ( audio IC )
Sep 27, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Static in speakers when treb in turned up and volume above 50%
the output ic is cooked. it is upc1130h2 or similar.
these chips are floating ground.do not ground one speaker lead.
outputs are typically 7 dollars.
it is mounted to the aluminum heatsink inside.you need to desolder and resolder the pins,and then solder in the new one.
special heat sink compound has to be applied,or it will go very quick
May 09, 2009 | Audio Players & Recorders
How to get a display ''protect off of my car audio?
one of your speaker wires to the internal amp is shorted. turn power off and make sure they are not touching metal or each other and then hit reset again. if this doesn't help your power ic may be fried inside the stereo or a speaker is shorted.
Nov 29, 2008 | Kenwood KDC-MP435U CD Player
Kenwood car stereo
are you aware that when you short circut any audio output of any audio it can lead do destruction of th e concerned audio driver( ic or output transistors) try and check the output ic and the concerned area.
Sep 11, 2008 | Car Audio & Video
KDC-9640 wont play
Apr 28, 2008 | Jensen KDC-9640
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
