Question about Jensen KDC-9640
I have a jenson kdc9640 car stereo when you turn the Volume above20 the sound goes off!! If I leave it at 12 works fine what's wrong ?
5 Suggested Answers
MrLard
  • 94 Answers
SOURCE: my source button will close my face plate
Hi, can't find man for m8815x, but got for m8805x. First I'll gamble that your close button is within 3/4 of an inch of the voldn, it's possible that when you press the close button you're also making the voldn button. could be due to impact Check that the close and voldn buttons 'feel' right. If the unit is very new, it could be a manufacturing fault. Bit of cruft inside, or a bad silkscreen on buttons, causing a bridge in the button matrix. Try rolling your finger left-right or up-down over the close button to see if it doesn't do the voldn every time.
Posted on May 04, 2007
MonsterG
  • 52 Answers
SOURCE: car stereo
if u got an amplifier, make sure u replace the fuse with a higher amp fuse, If the face for the detatchable deck got some kinda liquid, use compressed air to clean it a little bit, make sure alternator is charging and if ur car is not running then make it run to keep the battery chargin, :)
Posted on Feb 11, 2008
  • 103 Answers
SOURCE: car stereo receiver
Maybe the owners manual would help. It says you can adjust the sensitivity of the AUX input through a menu. It sounds like the AUX sensitivity is just set to max. Look for the 'to change other settings' chapter, instructions are in there.
If you don't have the manual, find it on the official website.
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
The link to download it is on the upper right.
Posted on Apr 13, 2009
  • 12 Answers
SOURCE: I have a Jensen car stereo, model cd4720. The
If you need to remove the head unit, have a look at the removal guides at www.carheadunit.co.uk
Posted on Mar 01, 2011
My 15”Jenson pa speaker. Is not working . Very little sound coming out
If it's only on one speaker the first check if the cable from the amp to that speaker is not ripped off .Tru swopping the speaker around to the side which is working if it still has no so sound the maybe you should check on the amp to see if you did not cut the stereo down for that channel .See that the balance dial is in the middle. Last of the easy stuff to check is to take your headphones and see if you get even volume of both sides don't forget to check if there is a stereo/mono switch you want this switch to be set to stereo though the sound will no change much cause your bass may be a little lower on mono.When you have finally tested all of these and no satisfaction, then one of your transistors of that channel is blown. But it can also be a cap that is leaking or blown.You can open the amp but disconnect the power before touching or opening .Look at the channel which is not working to see if you have a cap swollen or blown then replace it with it's same value micro farad (pf).It's difficult to say what else can be wrong but those are the first to look at.It will take even me around a hour to say whats wrong .Fault finding is what takes time . good luck
Nov 15, 2017 | Music
Problem with Blaupunkt 520 Stereo 1. Issue with volume control. when car is turned on the volume is 100% and have to manulaly adjust it. 2. When i turn on car it doesnt hold the stations and is on the...
It sounds like you need to make sure the yellow wire is going to a source that still has 12 volts going to it when the key is off. The yellow wire controls the memory of the radio and has to have a constant voltage going to it in order to retain clock and station memory.
Aug 09, 2011 | Car Audio & Video
Suddenly my yamaha Rx-v2300 only works to provide sound at nearly full volume to get any sound at all. This then comes with a background buzz. This only occurs while getting cable TV signal, using other...
I'm assuming you have a cable converter box (set-top box) that you have hooked to your receiver. Check the box volume using the cable company's remote control. These boxes frequently have variable audio output, and if you turn the volume down on the box you'll have the symptom you're describing. When you press the volume up or down buttons on the remote, you'll usually see a volume bar on the TV screen. As you raise the volume, there may be a point marked by an arrow, which is where you should set the volume. On some boxes, when you get to a certain level the words "best stereo" appear, and that's where to set it. If your box doesn't have some indication like this just leave the volume set 3/4 or full up. Then the volume on the receiver should function properly with the cable TV input.
Jan 12, 2011 | Audio Players & Recorders
I have a 32 inch toshiba t.v and my volume randomly comes on as zero, and If i turn it up it goes back to zero. When the volume is on the t.v I cannot turn the t.v off or change any of the chanels I can...
I would start at the front panel switches. It sounds as if one is sticking internally. If it is not a switch it would be a microprocessor problem. www.encompassparts.com has the switches. Part number 23344507. Unless you are good with a solder iron best leave this one to a pro. Thanks
Oct 28, 2009 | Toshiba 32A32 32" TV
Turn on the car or the stereo, volume increases to really loud!!
Set the volume for how loud you would like it to turn on, then push in on the volume button for about 20 sec, that will fix it
Jul 30, 2009 | Jensen's VM9312 Car DVD Player
Sound
Did you ever find a solution about the startup volume @ 12?
Oct 24, 2007 | Philips MCM298/37 Shelf System
Car stereo receiver
Apr 23, 2007 | Clarion DXZ555MP CD Player
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
