Question about Refrigerators
Water temp in shower changes radically with minute tap changes.
Dual tap system
  • 15935 Answers
SOURCE: shower mixer taps
look for a scald safety screw adjustment. Remove the handle, and it is underneath. this is for safety of young children, and is factory set.
Posted on Dec 23, 2008
  • 659 Answers
SOURCE: no water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Posted on Apr 10, 2009
  • 23 Answers
SOURCE: Delta tub tap only cold water no hot water or pressure for shower.
take handle off and adjust the nylon set ring it is to prevent kids from getting burned and is probably set wrong youll see teeth and a pointer just pull it out a little and turn it in the oppisite direction then push back in
Posted on May 12, 2009
  • 4 Answers
SOURCE: low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
Posted on Jun 24, 2009
  • 332 Answers
SOURCE: no stop tap. cold water coming through cold taps
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Bradford White 40 gal water heater,works fine, but has started whining when not in "low" setting. Seems to only do it during showers, or when temps drop outside etc. Only lasts a few minutes
it is possibly a high frequence '"water hammer" from a failing tap washer
call a plumber to replace all the tap washers especially the shower hot water tap washer
water hammer is when the water flow is intermittently interrupted ( (normally as banging pipes) but when it is fast it appears as a whistle or squeal
Dec 17, 2016 | Water Water Heaters
Water temperature has reduced even on maximum setting
check tap had a shower myself that would start hot then 3 minutes later hot was cold! then hot after 5 minutes.
I turned off main tap on meter, Undid tap fitting on shower found the washer was worn but also the tap fitting was seized could not turn it for full movement. You could soak the tap screw fitting in CLR and pull apart and use a tap grease on the screw thread or just buy another tap fitting. I discovered most of my tap fittings had calcium build up in them. But I replaced the shower tap valve thingy as it was really seized up.
Nov 22, 2015 | Home
Why does the water temp delivered from two Visu-temp valves in back to back bathrooms turn lukewarm after about 4 minutes.
personally I would change the temp setting to hotter water .isn't that why we have a cold water valve also to mix you will use less hot in the long run
Jan 15, 2015 | Water Water Heaters
Why does the water temp, delivered from two Visu-temp valves in back to back bathrooms, turn lukewarm in less than 5 minutes.
check the inlet tubes in the water heater suspect you will find it broke near the top of tank
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
Bathroon tub fixture--when I turn off the tap , there is still a drip of cold water from the faucet
One of the o rings on the cartage has a nick in it and it is easyer to change the cartage then to try to change the fallty o ring.
Jan 28, 2011 | Moen & Posi-Temp Single Handle Shower Or...
8" shower head with thermostatic
your litre per minute usage is probley greater than the recovery time on the cylinder..install a dual coil cylinder and pipe a heat exchanger off central heating system through second coil and you shall double the recovery time on tank,both coils should be controlled through pipe stats for effiency purposes
Jan 15, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
My water heater was serviced(drained and circ pump replaced) and I'm still getting lukewarm water for my showers. It doesn't get as hot as it used to at all. I can't even wash my hair-it gets cold too...
If the water is only cool in the shower, it could be the shower valve. However if water is cool at all taps, something is not working on the water heater system.
Dec 18, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Water from my shower tower is not hot enough. I have hot water flowing from taps all around the house. Only lukewarm water from my shower tower. What is the problem?
what brand of shower handles do you have and do you have just 1 temp handle or is it separate hot and cold?
Nov 17, 2010 | Home
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
