Question about Home
Just bought a hermle mantle clock with Westminster or Bing bam chime. How do I unpack it? Already cut rubber band and removed foam block. What else to get it going?
  • 277 Answers
Does it have a balance unit or a pendulum?
UsedClockParts.com
Posted on Jan 04, 2017
SOURCE: Seiko Westminster Chime Clock; Model No. QQF150G Caliber 12105
Does this help
http://www.theclockdepot.com/seiko_westminster_clock_instructions.html
Posted on Apr 22, 2009
SOURCE: seiko mantle clock (switchable chimes)
See this site
  • 15 Answers
SOURCE: I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMIN
Manually turn the minute hand forward until the 16 westminster chimes sound and then the hour strikes. Then remove the minute hand (it will go on in four positions) and put it back on at the 12 o'clock position. The chimes should now be back into sync.
Fred
Posted on May 10, 2010
  • 5 Answers
SOURCE: Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Posted on Jun 05, 2010
cashley199
SOURCE: tempus fugit westminster mantle battery operated
I had the same problem but the solution is unbelievably simple. Just set the hands to the time desired by turning the round button on the housing. Now you mmust tell the quartz timer/clock (plastic rectangular mechanism) the same time as you have set the hands. In this way when the hands hit the Quarter hours/half hours and the hours, the electonic chimes will chime the correct time.
Ultra simple. The two hour buttons and two minute buttons represent a 24 hour clock. Example, how to set the clock to 2:50 PM. Easy, change the 2 PM to its 24 hour counterpart, i.e. 14 hundred hours.
Move the hands to 2:55. Push the first button once for 1, push the second button 4 times, push the first M button 5 times, push the second M button 5 times. Move the set button back to run and there you have it. 1455 Hours. Not it should chime correctly. As a tip, use a brand new fresh battery to try this out.
Posted on Aug 18, 2012
I have a Daniel Dakota quartz mantle clock with Westminster chime but a black wire coming from chime housing and going in battery compartment came loose and it stopped chiming. I'm sure it's a simple fix...
It is the negative wire from the battery box that came loose. Need to solder it back onto the battery box negative attachment point. Have a good look at the battery box outer side where the previous soldering point should be visible and solder it back on at that point.
Nov 07, 2017 | Chime Home
Clock is ticking but not chiming
Have you ensured that the strike train is wound?
UsedClockParts.com
Nov 21, 2016 | Home
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register · My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
How do I fix the westminster chimes on my grandfather clock
Grandfather Clocks Manual - theclockdepot
www.theclockdepot.com/grandfather_clocks_manual.html
Howard Miller Grandfather Clock Manual by The Clock Depot offering discountGrandfather Clocks. ... The movement controls the hour strike, time keeping, andchime. ..... the hour without the Westminster melody if the other Westminster melody lever is turned to Silent. .... My Grandfather Clock has Stopped, Can I Fix It?
Owner's Manual - Master Clock Repair
www.masterclockrepair.com/ownersmanual.html
Note: The following information will apply to almost all grandfather clocks made after ...(See my article on Clock Myths) It is best if the chains are not pulled so far that the top of .... Some play the Westminster chime only and cannot be changed.
Nov 23, 2015 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS FOR SETTING THE CHIMES/TIME ON MY WESTMINSTER LINDEN MANTEL CHIME CLOCK
Fred
Apr 05, 2010 | Seiko Mantel Clock
Tempus fugit westminster mantle battery operated clock has 2 buttons under an H and 2 buttons under an M. how do I set the chimes? Amy Howard
Feb 08, 2010 | Seiko Mantel Clock
Home Logo
108 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
