How does mr. Christmas night before Christmas model no. 26605 turn on the window lights? music plays from the cassette.
3 Suggested Answers
  • 11 Answers
SOURCE: cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
Posted on Feb 26, 2009
Mr christmas carousel lights above each horse won't turn on
i would check any bulbs it might have some times it only takes one to blow to stop the others working.not saying this is what is going on with yours .
Nov 30, 2016 | Washing Machines
What size bulb do i need for Mr.Christmas Holiday lighthouse?
I can not say for sure but normally these types of houses take the same bulb you would use in a night light. like a GE 120V 4W
Nov 25, 2013 | Gemmy Mr. Christmas Light Show and Sounds...
I can't find the bulbs for the mr. Christmas musical bells
I found this one. I am in the process of finding out if it is correct or not. I hope this helps. I need a bulb badly too.
Apr 24, 2012 | Music
Can you repair a Mr. Christmas Nutcracker Suite music box?
Can Mr. Christmas The Night Before Chistmas music house be repaired. It is the large house with santa on Top and all the windows that light up as the story is told.
Dec 03, 2010 | Toys
Model: A8+
visit my website for all ur sound related problems...
go to support page in there...
all the best
Dec 25, 2009 | Pacific Digital (U30274) DVD±RW...
Mr christmas double decker carousel rotation stopped.
These things are really hit or miss. The company (Mr. Christmas) is virtually useless in the realm of tech support. Caveat Emptor and all that. Personally I have no use for this sort of thing but I must admit they ARE cute (when they work)!
I met a gentleman at the Citigroup Station Model Train exhibit (where I work as a train operator during the holidays) who had a problem similar to yours (in his case it's the music which doesn't work). I offered to attempt to fix this fellow's Mr. Christmas carousel (which he bought used, strike one!). Being a model railroader, I have vast experience repairing model trains but thought this might be a challenge. I did some online research and came to the same conclusion you did (ie Mr Christmas doesn't give a *%&^ once you've bought something, and there's NO viable tech support or schematics to be found). I was nearly about to throw in the towel and return it when I figured out how to open it. I will at least get you to the innards.
My guess is that these carousels are more or less mechanically similar (this fellow has the Disney Carousel, model 94448). The carousel consists of an outer "roof" which snaps around an inner roof (where the horsie poles insert; there are four little tabs which keep it attached to the outer roof). To get the outer roof off, however, you need to carefully remove the "crown" (which is glued on with some sort of silicone based adhesive) It is glued on with some sort of silicone based glue. BE CAREFUL removing it! Once the crown is off, you'll see a screw. Unscrewing it allows you to remove the outer roof.
If you feel mechanically adept enough, continue but TAKE NOTES as there are a LOT of screws and parts from here to the bottom base (where the motor and electronics are located). Once the roof is off, you will see the light wipers and contact pad. You will need to unsolder the two wires from the sprung wipers (be careful not to lose the springs!). You can now unscrew the hexagonal nut which holds the light wiper bracket/wipers in place. CAREFULLY remove this piece! You will now need to unscrew the contact board. pull it over the central shaft. You can now remove the inner roof. Once the inner roof is removed, you can lift up the main assembly (ie the horses, &c); CAREFULLY place this aside!
You are now at the base. There are several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. FYI the whole mess is a rubber band drive (sort of like an old cassette player or VCR). If there is no rubber band connecting the motor to the shaft, that is your problem! If the motor plain doesn't work, check the wiring fro the motor to the switch!
To reassemble, just reverse the directions. HINT: the roof will only go on top of the mechanism one way, so if it doesn't quite fit just rotate the roof until it does! Good luck!
Dec 27, 2008 | Toys
