When I turn volume above 20 sound goes off !!it work if it set about 12 ??
    Top Expert:
  • Televison & ... Master
  • 74,844 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Posted on Dec 15, 2016
2 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Sound Stuck on High
change the audio ic it has a short within.this will restore your set to normal dont forget to make checks in that same circuit as there might be resistors,diodes or caps that had contributed to the failure of the ic.good luck.
Posted on Aug 05, 2007
Kenwood KA 995 amp. volume control, as you increase or decrease the sound, a loud clicking sound is heard.
Katrina, this sounds like a dirty potentiometer (volume control knob). Try turning the unit off, and exercising the knob. That means turn it full turns, many times, like 70 times. Then try it again with power. Sometimes this helps.
Sep 21, 2016 | Kenwood Audio Players & Recorders
Why isnt my tv volume not working?
make sure you have tried the volume with the remote and the buttons on the set, if the buttons on the set work then their is a problem with the remote. if neither work then the sound circuit is bad in the set.
May 05, 2014 | Coby Televison & Video
When I set the effects to the channel for the mic, It kills mic volume
Check your mic input settings, click the "VOLUME" control (and/or sounds fron control panel)... also check and PLAY with "GAIN +20" on the settings..
Write me back on your results..and tell me your OS... question was vague..hope it helped.
Oct 18, 2012 | Tascam DP-02 8-Track Digital Recorder
Played samson 412 aura speakers for about 6 hours today with the volume at 1/4 of the way turned up.. the speakers became very hot and turned off by them selves.. I have them mounted on stands in a corner...
The volume setting on the speakers has LITTLE to do with how hard you are driving them. Your source might be extra hot and overdriving them. Read the specs on the speakers and use a sound meter to check your level. The speakers, being only 12 inch, should fill a room 20 foot by 20 foot to about 95 to 100 Db which you are only allowed 2 hours in MAX to prevent hearing loss. At 6 hours you should keep it down to 85 Db SPL. I know several deaf musicians that were exposed to high sound levels in rock bands... a deaf musician is kind of washed up.
Jul 03, 2011 | Samson Auro D412 2Way Active Speaker
Volume problem
Because perhaps it is showing how far below the level of maximum, eg -20 is quieter than -10.
Post more info re no sound please
Sep 22, 2009 | Pioneer VSX-108
STR-DE445 Works, but goes into protect when you turn up/down volume
This is a piece of **** unit. Mine only works on the left side, sometimes. When those times are I have NO idea. It doesn't seem to play 5.1 correctly and it goes into speaker protect mode for NO reason. It is TRUE lemon !!! ..let me know if you have any other problems with this JUNK .....schafe1001@aol.com
Aug 28, 2008 | Sony STR-DE445 Receiver
If its new call Sony and get service????????????
JVC Surround Sound System
The problem on your sub is your speaker is faulty the end of the speaker coil is burnt so at a certain volume it`s makes a short .I hope that would solve your problem:)
Dec 29, 2007 | JVC SP-PW100 Subwoofer
Sound
Did you ever find a solution about the startup volume @ 12?
Oct 24, 2007 | Philips MCM298/37 Shelf System
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
