Question about Refrigerators
Fridgidaire model fghn2866pf0 fridge. OP code on fridge temp. Changed sensor with no resolution to problem. Where do i go next
  • 22306 Answers
SOURCE: I keep getting a low temp error code PO128 on my
replace next?? your boy racer weekend mechanic scanner ,its leading you up the garden path ,if vehicle works ok leave it alone
Posted on Jan 18, 2010
  • 148 Answers
SOURCE: Fisher & Paykel fridge freezer, Fridgidaire
call that company server
Posted on Apr 05, 2010
  • 1940 Answers
SOURCE: I have a hayward 21002c heat pump heat pro, just
OP is the error code for a faulty Temperature Sensor. Since you replaced your Temp. Sensor, did you check the wiring? I have seen many of these units have the wires chewed up by mice, etc.
Just to make sure, you disconnected power to the heat pump prior to installing the new Temp. Sensor, right? If not, try disconnecting the power to the heat pump for about 5 minutes, and then reconnect the power.
Posted on Jun 24, 2011
  • 910 Answers
SOURCE: Hello I have a hayward
When you removed the original sensor did you try shorting out the connections to see if this removed the fault.
If it didn't then chances are you're right in the fact that you need a new interface board.
As OP stands for Open Thermistor and as a double check if you've got a continuity tester you could test the operation of your new temperature sensor to see how it operates. Should be closed contact that opens when hot.
Posted on Jun 25, 2011
SOURCE: I have an Gallery series
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Posted on Nov 07, 2011
Fridge started working again after I cleaned the grill, then freezer stoppped, unplugged and waited now freezer is good but fridge won't stay cold. The temp says 56. Ugh! Model # is PLHS67EGSB4.
My Freezer is Cold But My Fridge is Not! - YouTube
? 1:51
Nov 5, 2013 - Uploaded by Appliance Princess What to do if your refrigerator is warm, but your freezer is stillcold. ... Cleaning them is a good idea, even if it isn't the cause, because it will improve the fridge's efficiency. ... How does thefreezer fan's failure cause a fridge not to stay cold? .... How To Fix Your Fridgidaire Refrigerator (if the compressor won't ..
Sep 23, 2015 | Refrigerators
Why is my Frigidaire model FGHN2866PF0 not sealing correctly.
You may need to replace the seal. When the fridge was leveled, was it checked front-to-back as well as side-to-side? Were hinges checked for misalignment and binding?
Jul 22, 2014 | Frigidaire Refrigerators
My Corsa B 1.0 cuts out
run the fault codes to find which sensor is faulty.
Nov 16, 2013 | Opel Cars & Trucks
P0128 indicates coolant temp lower than expected and P0522 indicates low input from the oil pressure circuit. The first one sounds like a thermostat possibly stuck open. Check coolant temperature. It should reach approx 195 degrees. The second one could be a bad OP sender, low oil pressure or some other problem on that circuit.
May 10, 2011 | Dodge Neon Cars & Trucks
Fridgidaire Mini Fridge not cooling
pulled off back panel on inside of freezer, to find it was a solid block of ice. thawed, and plugged back in... working properly
Feb 08, 2010 | Electrolux Refrigerators
Cannot get the fridge to start cooling
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Did you think this was helpful? Yes No
Feb 08, 2009 | General Electric GFSS6KKXSS Stainless...
Fridge too cold
The temp sensor or the thermostat is bad.
It is reccomended that the sensor be replaced whenever a T-stat is replaced.
You can purchace both for less than 50 bucks with most models at your local appliance parts warehouse.
(The T-stat is the part that you turn up or down to adjust temp and the sensor is the wire coming off of it to a remote location in the fridge. With some models it is all one part, with others the sensor can be removed seperatly.)
Dec 30, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
