Question about Locks & Locksmithing
How to put Kaba L1000 into Zero Code. I have done it by accident before, but I need to now and since I have 5 locks to manage, don't want to mess this up. thanks!
  • 10865 Answers
SOURCE: L1000 keyless lock at our office that we can't reset 4 digit cod
You can call Simplex at 877-439-5377. They will be able to assist you. good luck
Posted on Jan 22, 2009
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: Forgot code to Unican L1000 lock. How can you
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
  • 963 Answers
SOURCE: Zero old key code and enter new key code on KABA
http://www.kaba-ilco.com/access_control/literature/literature_grid_eplex.aspx?id=14
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
  • 963 Answers
SOURCE: The KABA L1000 Simplex lock
I recommend that you contact Kaba Ilco directly with your problem.
Posted on Nov 05, 2011
Have simplex lp1000 keyless lock sytem is zeroed out but will not reset or take new code, aleays stayes unlocked
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Good luck--and please provide feedback if this helps!
Oct 31, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Model 1011... door opens without any combination. how do i fix the lock to open only with combination?
Aug 15, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Door opens without any combination. how do i fix the lock to open only with combination?
Opens with out a code and can not get it to stop pulling the latch back. i tryed to put a new code in but cant grt past step 2
I THINK that the problem you describe is because the lock is in "Zero Code":
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE."
Go to this web page:
and position your mouse on PDF under the "TIPS" (rightmost) column on the grid line for the L1000.
Two choices will pop up; click on the upper one "Changing the code/Combination...." and download and open this file.
If it does not open, you need to download and install Adobe Acrobat on your computer from here: http://get.adobe.com/reader/ It's free!
When you get this document open, you will see the statement that I quoted from the top about the Zero Code. At the bottom of the document you will see:
Troubleshooting
Symptom/problem: Outside knob/lever when turned always retracts latch without depressing
any buttons.
Cause: Lock is in zero combination.
One last nasty piece of information: If you don't have the necessary DF-59 Key or spanner wrench mentioned in the procedure, you can get either from these sources:
Key:
Whew! That was a lot of stuff, to digest, so I hope it helps. Good Luck!
Jul 14, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Can a L1000 series simplex kaba be switched to mount a right handed door
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
under L1000/Specification/SimplexL1000 Catalogue PDF
Apr 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How do you zero out the Unican L1000 (with levers)? The lock is not responding to the old or new combination.
Yow will find a link to download the manual for your model L1000 on this page:
This will download a PDF file; you will need adobe reader installed to open it. There is a link on this same page to download adobe reader.
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 14, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
The KABA L1000 Simplex lock that I have won't open from one side of the gate. The master key and correct code will turn the handle, but the latch doesn't engage. The latch will open from the other side...
Feb 02, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Door does not lock when closed.
Jan 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
When i turn the knob without entering the combo, the door opens. When I enter code, the door doesnt open. The passage knob is in the correct position.
Jan 07, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
102 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
