Question about RCA Televison & Video
I bought an RCA smart tv and it was working fine until I picked up the RCA remote to change channels and now I get "no signal" on my TV screen. How do I fix this?
  • 209 Answers
What was going on before you picked up the remote? Did the remote work OK to initially turn on the TV? Where you able to change channels prior to this issue? If yes, then maybe you accidently changed the source mode of the TV via the remote?
The source mode button chooses what signal you want to use for getting a signal transmitted to your TV (E.g., antenna, HDMI, etc.) If the source button is clicked to something that is not supported (E.g., Line1, or Line2, or Line3, or a particular source like the antenna option is not set-up properly to receive a signal, then you will receive a, "no signal" message".
Posted on Dec 23, 2016
My Tv no longer registers a signal from the antenna. I can see a picture thruogh my smart DVR and Chromecast but no pic with TV antenna. I bought a new antenna, still no signal.
Is the TV set to air or cable? It has to be set to air/antenna and a channel search has to be done first before a picture will show.
Mar 07, 2016 | Zenith Z50P3 50 in. Plasma TV
How can I use an RCA universal Remote to pull up smart hub on my TV
RCA samsung smart hub Remote Controls Questions ...
RCA remote controls samsung smart hub related questions and answers. ... Pull upprevious . ... Set-up (Programming) procedure is too much to type in here, and is not ... How do i program my rca universal remote to my TCL 55 IN smart tv?
How to Program an RCA universal remote « TVs & Projectors
Mar 26, 2010 - If you just bought a new RCA universal remote and want to program it then this is for you. The first thing you have to do is hold down the TV button and tap and ... So do a little labor, pull out the remote, and kick your feet up on the table ... by step how to set up and work your remote control to enjoy carefree, ...
HOW TO PROGRAM TV Channel Button on CABLE Remote ...
? 3:20
Jan 19, 2016 | RCA Televison & Video
Why did my remote that i bought with my rca television stop working to tv an no universal remote will program to it ? could it be the sensor ? because otherwise everything works fine on tv you just ha
Try replacing the batteries of the remote first, and make sure there is no corrosion on the contacts. If that fails, you may have to re-program the universal remote for your TV. If that fails, then you either have a problem with your remote, or the sensor of the TV. Hint, use a digital camera to look at the "light" (LED) of the remote while you press the button. The digital camera can "see" that infrared light, and you can see it on your digital camera screen! This works with dedicated digital cameras, but may not work with smart-phone cameras. For example, it does NOT work with my iPhone, but does work with my Sony digital camera.
Oct 21, 2014 | Televison & Video
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
I just bought this tv ws-55613 from a friend, when I looked at it i hooked up a dvd player and it worked great.after igot it home, i hooked it dish network. It worked fine until i started to play around...
This is 2003 model and does have a hard reset. It will return set to as it was when new in box, on air band on channel three, most likely you did something with remote that changed something.
I am in California and can tell you how to with the set on with the Mitsubishi remote enter the OPTION MENU AND RESET IT.
SD TECH (in San Diego)
Aug 22, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Lg tv interferes with my virgin media box. channels change on their own, turns on and off, and generally goes mad. not the remote. removed batteries and had new. had new box off virgin and still the same....
I had the same problem so I moved the virgin media box to behind the LG TV. Problem solved as an infra red sent out by the TV on power up doesnt affect the digibox anymore.. ;0)
Nov 11, 2009 | LG 42LC2D 42 in. LCD HDTV
My remote control doesn't work. nothing happens when i use it
It can be a faulty infra-red receiver board, usually wont pick up signal from wide angle or distance. what is your tv?
Mar 18, 2009 | Televison & Video
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
