Question about RCA Televison & Video
Have an RCA LED55G55R120Q TV. Only audio when turned on. Screen very faint hue, no video. Will come on if I unplug/plug it in or turn off/on several times. Sometimes takes half an hour.
    Top Expert:
  • RCA Master
  • 77,202 Answers
Read the info at the link, it may help to diagnose this. TV Boards Buying Guide
Posted on Dec 14, 2016
How to turn off internal speakers on rca led55g55r120q tv
You can't normally if using the HDMI cable, although you could check in Settings - Sound. The small 3.5mm jack usually has a mute for the internal speakers.
Your manual doesn't mention it, so no you can't. RCA are inexpensive basic sets.
http://www.searspartsdirect.com/partsdirect/user-manuals/LED55G55R120Q-RCA-LED%20TV-manual
Dec 31, 2016 | RCA Televison & Video
Flatscreen Television isn't turning on. I'll plug it in and the light to the left side turns red with a black screen.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 14, 2015 | Generic RCA LED55G55R120Q 55" 1080p 120Hz...
RCA flat screen TV turns off by itself and won't turn back on
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | RCA L22HD41 22 LCD TV
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Hi. I have an old RCA tv, model # T09081bc. I was hoping to hook up my Playstation 2, but the best result I've gotten was a black screen. I have two different cables for it, one that plugs into the cable...
After you plug the Yellow (video),Red (audio 1) and White if Stero (audio 2) turn the Playstaion on, now turn to chanel 3. does it work? if not look for selector on TV (video input,aux) or use up-dn chanels until you get playstation screen.You can also plug the round antenna cable from TV to unit and set TV to 3 or 4.Good Luck.
Sep 05, 2009 | RCA T09081 9 in. TV/VCR Combo
No image, sound is on
check the rca cables, specially if they the chep kind, I had so many problem with these cheap rca cables I quit buying the cheap kind, they give me too much prblem.
Aug 12, 2009 | Initial Televison & Video
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
