Question about Maytag Washing Machines
Remove agitator in Maytag Ensignia - Maytag Washing Machines
    Top Expert:
  • Maytag Master
  • 77,939 Answers
Posted on Dec 14, 2016
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag washer mav4757aww was agitating a little then would stop and make a slight humming sound. Now it won't agitate at all , it just hums and starts to smell like something is getting hot. It will...
Unplug the unit and remove the front panel and look at the space between the motor and transmission find the coupler that connects the two together this could be broken. You may have to lay the unit on it's back to check this out. It's a cheap fix if its the coupler. Let me know.
Sep 27, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
All of the fins broke off of my agitator and my machine is only 3 years old.
what were you washing? You can get a new agitator, go to and put in the model number to pull up a diagram.
Apr 15, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
My maytag ensignia fills with water but stops after that. if you turn the knob to the next step, it will agitate but it wont go to the next step by itself.
Thanks for using FixYa. From what you have described it seems that the Timer(part#7 in the picture) has gone bad and needs to be replaced.
Also, check the Timer knob and if you hear a clicking sound then its certain that you need to replace the Timer as everything else seems to be working fine. Please do accept the solution if the issue is resolved or else revert for further assistance.
Apr 13, 2010 | Maytag Ensignia MAV3757AWW Top Load Washer
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
Oct 21, 2017 | Maytag Ensignia MAV4758AWW Top Load Washer
Squealing during agitation...drum seems to be 'sticking' ....
could be several things if it is an intermittent squeak that goes in time with the agitation then you have bad brakes if it is constant then you may have a bad pump or object in the pump
Sep 19, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Maytag washer MAV4757AW load squeaks during agitation only
You may have some bad bearing in the shaft assembly. i would take a look at this. also, if its not a direct drive, you may have a bad belt as well.
Mar 16, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Open Questions:
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
