Question about Kenmore Kitchen Ranges
I have a new kenmore Lp range . I cant get the flame to burn blue on the broiler. I have done the Lp coversion .All other burners work fine.
SOURCE: changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Posted on Nov 22, 2007
bigg t
  • 640 Answers
SOURCE: Yellow flame
lp burners dirty.clean out the orfice and burner and this should solve your problem.
Posted on Dec 11, 2007
fknstart
  • 404 Answers
SOURCE: kenmore range broiler burns orange not blue and leake gas
probally wrong gas pressure
Posted on Jan 05, 2009
jumptrout51
  • 3361 Answers
SOURCE: Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Posted on Feb 21, 2009
brnspncr
  • 67 Answers
SOURCE: Nervous about over tightening ... how tight before causing damage
You should contact the supplier of your oven as there may be a gas pressure reduction valve for the oven that requires adjusting. It needs to be done with a gas momoneter so not really any thing you should attempt your self.
Posted on Jun 11, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of soot...how fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
The oven and broiler work but the broiler flames up like its not getting enough air. the flame burns yellow
you may be correct with the air? is it LP or NG? air adjustment correspond with type of gas also the brass orifice you see going into the burner may be in need of ajustment, if its LP its needs to be screwed all way back even if it seems tight, screw it out away from burner ( clockwise) if NG then it's oppisite. hope this helps
Feb 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
May 27, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore range broiler burns orange not blue and leake gas
The only real important thing is blue flame with a orange tip,
also ranges have different nozzles for Natural Gas (NG) or propane(LPG)
he can check for leaks with soapy water at the flex line connection
Jan 05, 2009 | Kitchen Ranges
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Yellow flame
Dec 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
