Tv turned on with remote, sign please ensure aerial is plugged in. do you want to start automatic search yes no. can't get further using remote. 2 green lights left of box and 1red light.
    Top Expert:
  • Televison & ... Master
  • 80,668 Answers
Do you have a digital to analog signal converter hooked up to the TV? If you use an antenna to receive the broadcast signal you need the converter box. You can buy them on eBay for cheap.
Posted on Dec 14, 2016
How do i search for codes on urc20-d1f
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Jan 02, 2011 | Televison & Video
Cannot get RadioShack universal remote to connect with TV. Used codes listed time and again but with no success. Spent hours using automatic search, and, from time to time, the TV would switch off...
On most RadioShack universal remotes, when you are running the automatic search, you have to press a button within 2 seconds of the TV switching off or it skips to the next code. If you fail to press the correct button within 2 seconds, the TV wont respond when you subsequently test the code.
I am not sure which is the correct button for your remote as you did not specify the model number of your RadioShack remote. On many models, it is any button other than the "SET" button.
Although getting the TV to switch off is an encouraging sign, there is still the possibility that your RadioShack remote will not work with your TV. There are hundreds of universal remotes, hundreds of TV brands and thousands of different models. This makes for an incalculable number of potential
combinations of remote and TV and many of these combinations simply don't work together.
If you have tried all of the codes supplied for your TV brand and completed the automatic scan with no success, then it's likely that you have one of the combinations that doesn't work. However, you
should ensure you are "setting" the code in the remote as soon as the TV switches off. For correct operation, please consult the instructions for your remote.
It is also possible that a code for a different TV brand will work for you as many TVs are not manufactured by the company with their badge on the front. If you can discover who manufactured the original TV (base-unit), then codes for this brand will sometimes work.
If you would like further assistance, please post back with the brand and model number of both your TV and the RadioShack remote. I will then be able to check on the correct programming instructions for your remote and possibly determine whether codes for another brand will work.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
Hello i need codes for asda's universal remote model URC20-D1F so i can sync it with my BEKO tv please can you help?
URC20 D1F
1. Turn TV on
Dec 27, 2010 | Beko 142746 TV
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 23, 2010 | Televison & Video
I need the codes for an ASDA remote control, model no: URC20-D1F
URC20 D1F
1. Turn TV on
May 09, 2010 | Universal Remote Control Remote Control
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
1. Turn TV on
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
How do I retune DMTech TV Freeview with DVD video please?
Please fallow bellows instruction to retune your TV.
Could you please follow that EEPROM RESET INSTRUCTION OR FIRST TME INSTALLATION.
Also please don’t forget that MENU BUTTON from your remote, it’s not the one in the middle of remote.
There are the other MENU BUTTON in left down bottom side.
Cannot access Digital TV and am asked for a Lock code Key?
If you cannot access the Digital TV option then conduct an EEPROM RESET as mentioned above. If you are prompted to enter a lock code key enter three / four zeros.
Alternatively when prompted to enter the lock code key conduct a FIRST TIME INSTALLATION also mentioned above.
There are two options available. The first option is to conduct a general reset that will reset all user preferences. The second option would be to conduct an EEPROM RESET. An EEPROM RESET would reset all the internal hardware.
Instructions - Please refer to your DMTECH remote control and user manual provided
1. Turn the Television ON ? Button on front of Television / Power button on remote control.
2. Make sure that you are on Analogue television by pressing the TV/DVB-T button until you see PR and the channel number selected in the top right corner of the screen, e.g. PR 1.
3. You must then Press the button labelled Display until a window titled INFORMATION is displayed on the screen.
4. Only when the window titled Information is present can you continue by pressing the digit (1) twice and then pressing the button titled LINE. If you make a mistake then press Display again to remove the window titled INFORMATION and repeat the process. (Display - 1 1 - Line)
5. Once you have successfully completed step four you will notice that a menu appears on the left of the screen. You can then select which option you want, either RESET or an EEPROM RESET using the arrow keys. To execute an instruction please use the RIGHT ARROW KEY and not the ENTER button.
Make sure you have properly conducted a FIRST TIME INSTALLATION and an AUTOMATIC SEARCH. If having done this you can try conducting a manual search in an attempt to force / lock the channel.
This will erase the DVBT tuner memory and reset the interface card. This may resolve poor channel reception, the inability to store channels or even receive certain channels.
1. Turn the Television ON and select digital television by pressing the button labelled TV / DVB-T located under the power button on the remote control.
2. On the remote control locate and press the button labelled Menu, found at the extreme bottom left of the remote control.
3. A Menu should now appear displaying options. Scroll down and select the option labelled SETTINGS using the ARROW KEYS and the enter key located in the middle of the remote control. On the next menu you must select INSTALLATION to move on to the next menu.
4. On this last menu scroll down to the last option labelled FIRST TIME INSTALLATION and select it pressing the enter key. You will then be prompted to delete all channels, using the left arrow key to select yes and press enter to execute. The television will reset and prompt you to commence an AUTO SEARCH. Follow these instructions to tune in channels.picture
Digital Television requires much more from existing aerial systems. Having more than one digital TV may reduce signal quality and strength depending on how the aerial system is set up. It is therefore recommended that if you decide to use more than one digital television you use a booster and or at least make sure you are using a digital ready aerial. Using an existing Aerial that is split may reduce signal strength depending on how many times it is split. Please see the diagram below. The best solution when using an existing aerial is to purchase a booster device. Aerial Splitting - Why a booster is recommended. A booster is used to apply a small current that boosts the existing signal. A booster can be purchased from all main TV/HI-FI - consumer electronic product retailers.
Jan 16, 2010 | Televison & Video
Humax PVR 9200T freezing picture and will not turn off.
Unplug the aerial; switch the PVR On; if you have control via the remote do a reset to default settings thus:
1. press Menu on the remote
2. select Installation and enter default password of 0000 unless you have changed it
3. select Default settings and okay on YES
4. then turn if off again via the remote
5. plug the aerial back in and it will scan for channels, save them of course.
I got help on this from other forums but saw your request for help. This worked for me.
Oct 25, 2008 | Televison & Video
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
