Question about Krups Coffee Makers & Espresso Machines
Krups EA9000 error code 13 minimal output, frequent prime cycle.
  • john cushing
    john cushing Aug 16, 2017
    I've got the same error code 13 on my EA9000 can someone help? John Cushing
2 Suggested Answers
FAV6800AWDIY
  • 526 Answers
SOURCE: Getting dc error code in rinse cycle, 13 min.
See my Clutch Fix post. Anyone with basic mechanical skill sets can save there $1000 machine for low cost maintenance or Clutch pulley replacement.......Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Posted on May 15, 2010
My Krups EA9000 and it shows error code 3. I brought this machine from UK to South Africa when I moved. People here who service Krups cannot find appropriate manual to fix this error code. Any ideas?
If the people in SA are authorised service agents they may need to contact the technical dept at Groupe SEB SA to get the info. It's not available online through the normal service centre channels.
Jul 28, 2017 | Krups Coffee Makers & Espresso Machines
Krups EA9000 Dosing of beans.
Plug it in, turn it on and then within 3 seconds touch each of the 4 corners on the touch screen in this order Top left, Bottom right, Bottom left, Top right that should open up the settings options for you, follow your nose after that.
Jul 28, 2016 | Krups Ea9000 Barista Espresso Machine
What does code 26 indicate?
Check the float in the tank, if it is not floating up from the bottom then jam something plastic underneath it to activate the water level sensor. You can either continue to use it like that ans check water level before you brew or buy a new tank, there is no repair for a float.
Jan 23, 2016 | Krups Ea9000 Barista Espresso Machine
How do you remove brew unit
I have done XP9000, this may be similar. Remove side cover, operate lever on side of exposed brew unit and pull brew unit out with the handle. You can only do this when machine is in normal 'at rest' position. Unit will not come out in any other position.
May 06, 2015 | Krups Ea9000 Barista Espresso Machine
How is it possible that everytime the machine starts with the message maintenance required,when the coffee is not even finished
Could it be that the machine needs a cleaning cycle to be run or a descale done. If neither of the above it will mean the machine has detected something about the process is outside normal parameters and should be looked at.
May 05, 2015 | Krups Ea9000 Barista Espresso Machine
Error code 06
Look for the leakage source:hoses, actuator, priming valve?
Switch or distributor switch control fault: incorrect detection of cams error in distributor position in cylinder descent phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
Jul 08, 2014 | Krups XP7260 Espresso Machine
Unschedules maintence
Defective electronic components.
Mar 04, 2014 | Krups Ea9000 Barista Espresso Machine
Krups error code 4
Prosz? o pomoc...mam krupsa EA9000 i wy?wietla mi code:4 , nie wiem jak si? do niego dosta? do ?rodka
Jan 15, 2014 | Krups Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
378 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
