The rubber on the rear roller(drive) broke. model ebs7076
    Top Expert:
  • Office Equip... Master
  • 8,204 Answers
Your best bet is to get in touch with the company who sells or makes it.
or try ebay.
Posted on Dec 14, 2016
Brother M-100 Won't Grip Paper
Best way is to remove the top cover, with out taking the Platen(large rubber roller) that the paper goes around out look to the rear there is a spring that breaks that puts pressure on a pan with feed rollers in it , replace spring or at least put a new hook in it or if you are lucky and it is not broke I could just be unhooked. Also clean all those rollers that are rubber with something nail polish remover. Do not touch plastic with this cleaner, it may melt plastic.
Apr 04, 2014 | Brother Office Equipment & Supplies
I have a Proform Model PCTL42061 that has a roller pulled forward since the rear cap broke on one side. where would I get a rear cap for this older model?
Dear Sir:Go to the next web : www. or www. or www.
sincerely. God bless you
May 03, 2012 | Proform Exercise & Fitness
I have recently been given a HP K8600 which I am told works perfectly except for the front paper feed. It is fine using the rear feed. is it aproblem that can be repaired or do I just use the rear feed?
Well, my guess is, it could be the roller foot or a belt. If you are comfortable taking things apart and putting them back together, it may not be tough to fix, but finding replacement parts may be tougher than actually installing them.
Typically, the paper feeders work by a belt that turns a roller, the roller has a rubber foot on it, this rubber foot grips the sheet of paper when the paper is pressed to it (in many models there is a "lifter" that does this.
You can try with the front feeder and see what it does. In most cases if you look closely you can see the printer working in action. When you try to print something, does the rubber foot spin? does the paper get lifted? (or the foot lowered to the paper) If the paper is applied to the "foot" and the foot spins, and the foot can't grab the paper, it could just be a worn out rubber foot. If you can find a replacement, that may be the simplest thing. But really overall, if you are fine using the rear feeder, it may not be worth playing with unless you want a project.
Mar 08, 2011 | HP OfficeJet Pro K8600 Printer
Model 158.1786080: bobbin rewind will not rotate. Rubber on drive wheel seems to be worn below size limits.??
i think you have solved your one "Q" and your right .. the wheel is warren out or the rubber is gon hard and will not pick the drive . some models have just the rubber ( wheel ) as a replacement . an other will have to relaplace the inner (drum) and rubber as assmbl..
Jan 15, 2010 | Sewing Machines
Paper jamed
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
My vacuum has good suction but i can hardly push it across my carpet. any answers????
is your brush roller turning,that would cause it to be hard to push .the brush roller helps it walk across the floor.if your brush roller isn't turning then your belt is broke or the brush itself siezed up.unplug the vacuum and try to turn the brush roller .if it turns real free then your belt is broke.before you replace the belt always clean the motor shaft ,the old rubber from the old belt melts onto the motor shaft .if you don't clean it your new belt won't last very long.please leave feedback
May 04, 2009 | Kenmore Vacuums
Electrolux FGX831FS1 dryer drum, only spins one way manually
Check inside the drum to make sure the three screws in a triangle in the rear center are all there, if they fall out the drum goes off center and the motor can no longer drive it.
This model has no rollers, the front of the drum has plastic glides mounted on the front of the drum that ride on teflon impregnated pads that are glued around the door.
The rear is supported by a steel ball screwed to the rear of the drum (the 3 screws that I think are causing your troubles) that rides in a plastic saddle screwed to the rear of the machine.
If the excess drum movement is only up and down you should replace the front glide system.
Good Luck
Apr 26, 2009 | Frigidaire FEX831CS Top Load Stacked...
Double sided copying: Paper Jam at Rear Cover @ rollers;
Put your thumb on the lage black rubber roller and try to move it.
You might need hemostats to grab scraps.
Mar 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Very loud
Rubber tired drum support rollers or drum felts have worn
open case and remove drum
as described in any of the 'change belt' posts
examine rollers. at rear of drum
if damaged replace in pairs
52318c9.jpg If rollers are good(unlikely) examin felts and nylon glide surfaces
Nov 02, 2008 | Frigidaire GLER642A Electric Dryer
Need help ASAP
sir you should check your computer software ,I dont think that it is the printer problem or
Oct 03, 2007 | HP DeskJet 710c InkJet Printer
