What would cause the flame to be extremely high on a Kozy heater?
  • 3 Answers
SOURCE: heater lites then goes to low flame will not stay on high flame
Pilot sensor or thermocoupler
Posted on Feb 04, 2009
  • 58 Answers
SOURCE: heater registers extreme high 'outside' tepurature
cabin temp sensor need to be replaced
Posted on Aug 02, 2009
  • 221 Answers
SOURCE: Kozy World propane wall heater
The ceramic "bricks" need to be heated evenly. Since 3 are good, I would have to assume the other two have a restriction. Maybe a spider in the orifices, If  you can access the "jet" where gas comes out, try using a paper clip or something similar to clear any blockage. If that wont do it, pull the burner, remove each orifice and clear. Good Luck
Posted on Dec 30, 2009
Testimonial: "Thank you very much for the info. There was some trash around the opening of the 2 jets. I cleaned them out with a tip cleaner and now it works fine."
SOURCE: The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Posted on Sep 10, 2010
  • 47 Answers
SOURCE: I just bought a brand new Kozy World blue flame
The thermocouple is bad or not aligned properly. It is the metal bar in front of the pilot light. This bar senses the heat put off by the pilot light. If it does not get hot it will not allow the gas to flow. You either need to align it so that it is in front of the pilot light and receives enough heat to allow the gas valve to operate or possibly the thermocouple has gone bad and needs replacing.
It could also be that you are not waiting long enough. The thermocouple must sense the heat for at least one minute or more before it will let the gas valve turn on. Turn everything to off for at least five minutes. Re-light the pilot light and let it burn for at least one minute and then try turning the knob to on.
Posted on Nov 25, 2010
The pilot ignites without a problem. It will stay lit. However, when you try to kick the flame on, it will burn for about 15-20 seconds then the whole unit kicks off.
Sounds like a over heating or a thermostat problem. Is there a safety (high limit) thermo in that unit? Replace it or jumper it temporarily to see waht happens.
Before you do that, make sure the air flow is in no way restricted causing over heating in the unit and for the thermo to open, shutting down the unit.
Oct 26, 2013 | Kozy World World Marketing GWD208 20,000...
I have three Kozy World wall heaters. Two work just fine - the bricks turn red after the heater has been on for a while. The third one always burns blue and the flames 'lick' the top of the inside of the...
Yes, it sounds like the third heater has a Control Valve problem. It's allowing more gas into the system than what it's supposed too. Have you tried turning the flames down to a lower setting? If so, did it lower the flame height? How old is this heater and is cleaned and serviced at least annually? Are you using Natural Gas or Propane?
Please get back to me with the answers to the above questions and I may can help you.
Thanks,
Rich
Feb 07, 2011 | The Companion Group Kozy World Portable...
Pilot flame pops and gets llonger then shorter
From what you have described, it sounds like a pressure problem with the gas. Contact Kozy World (you can find their home page on line) and speak with their Tech Service Dept. Also, the gas in the tank pay be very low.
Jan 31, 2011 | The Companion Group Kozy World Portable...
The pilot works and the flame comes on but when the flame goes out so does the pilot light
Uswually when that happens it is because the pilot is too weak... the pilot is not focused on the thermocouple properly or the thermocouple is weak...
You will need to figure out which of these things are causing your problems...
heatman101
Jan 04, 2011 | The Companion Group Kozy World Portable...
Pilot light goes out when the burners shuts off
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Dec 19, 2010 | The Companion Group Kozy World Portable...
Thermostat problem
I WOULD JUST DOUBLE CHECK THE WIRING TO THE THERMOSTAT AND THE HEATER, , WOULD BE MY GUESS, IF IT WORKED FINE BE FOR, THERMOSTATS DO GO BAD, BUT I WOULD CHECH WIRES, ALSO YOU MAY BE ABLE TO CROSS THE TWO WIRES AT THE THERMOSTAT TO CREATE A DEMAND FOR HEAT, BY PASSING THE THEMOSTAT YOU WILL KNOW IF THE PROBLEM IS AT THE THERMOSTAT OR HEATER GOODLUCK
Jan 24, 2010 | The Companion Group Kozy World Portable...
Dec 09, 2009 | The Companion Group Kozy World Portable...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
Oct 26, 2009 | The Companion Group Kozy World Portable...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
