Question about Dryers
Need to replace an Endurance B3R plastic roller with a bearing inside it under the seat adjustment. Where can we buy this part. I have images of the broken part and where it goes on the machine.
SOURCE: Cosco Buckle Broken
I need a new plastic buckle for my car seat straps
Posted on Sep 30, 2008
  • 461 Answers
SOURCE: Buying and replacing just the transfer roller on a Dell 5110cn
Maybe if you call you can order just the transfer roller. You could try removing it and cleaning the ends (to provide better electrical contact). You could also try wiping the roller itself with a lint free dry cloth - but do so at you own risk and never touch the roller with your fingers!
Posted on Dec 09, 2008
  • 16 Answers
SOURCE: Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Posted on Feb 15, 2009
  • 10 Answers
SOURCE: the 4 plastic brackets that adjust the bed spring up or down have broken, can these be replaced and where do i find the replacement parts. thanks for any help
You can email them - they emailed me the instructions and parts list in a 16 page pdf.
Here are the instructions for your crib. Please review them and see which parts you will need. We accept Visa or Master Card. Parts are non returnable. Delivery is normally 7-10 business days. We do have replacement parts for this crib. Please review the instructions and see what you will need. J Thank you, CindyCustomer Service RepSimmons Juvenile Furniture':Phone: 1-800-218-2741 ':Phone: 1-920-779-40047:Fax: 1-920-779-4216
Posted on Jun 01, 2009
  • 3911 Answers
SOURCE: Broken seat adjustment wire under driver's seat...
On the 90s S models there were two screws holding the rails in front and two in back. remove those bolts, disconnect the battery and then the seat belt light wiring plug and the thing should come right out.
Posted on Nov 25, 2010
Testimonial: "Thanks! I had not considered having to disconnect the battery before unplugging the wire under the seat. Very insightful and helpful!"
How do I change rear wheel bearings in my 2010 ford bantam rocam? Must the nut be very tight?
adjust the brakes back off so that the drum can be pulled off first
next remove the grease cap, and split pin
remove the tin nut and the axle nut
pull the hub off the axle
replace the bearings after repacking the cones correctly ( grease between rollers under the cage )
reinstall making sure that the grease seal lip is facing the bearings
install the hub back on the axle and install the nut
do it up until it touches the bearing , spin the hub and do it up a bit more while turning
This ensures that all the tapered rollers are seated correctly
Now without touching any thing undo the nut then do it back up until it touches the bearing again
This is a no pre-load - no end float position that is desirable for the bearing
fit the tin nut positing it so that the split pin can go through the axle hole. If after many changes of position of the tin nut you still cannot get a section to line up with the hole , adjust the axle nut up just a bit until something lines up
any more than one castleantion hole will be too tight .
fit grease cap without filling with grease as that grease will do nothing
what you have put between the rollers under the cage will,be sufficient
Dec 30, 2015 | Ford Cars & Trucks
9 out of 10 times the issue is a worn out clutch bearing or "one way needle bearing". Freemotion and Nordic Track are both owned by ICON Fitness. This technology for fitness equipment comes from the original Nordic Track skier. In the skier, there is a flywheel with an axle through it in the middle with skis left and right. Under each ski just about center of the length is a rubber roller that fits over the flywheel axle. Inside this roller is a "one way needle bearing". That is, when you push to the rear with the ski, the bearings rollers will shift and lock against the axle and engage the flywheel. When you pull the ski back forward the rollers inside the bearing release the axle and allow free movent forward untill you again push to the rear. Many poor souls were sold new skis and tension straps in most cases to no avail. What needed to be replaced or rebuilt were the rubber rollers under the center of each ski with the "one way needle bearing clutch" inside. The same technology is used inside this exercise bike except that the "one way needle bearing" is pressed directly into the flywheel itself. So rather that replacing or rebuilding the "roller clutches", you need to replace or rebuild the "flywheel". The price for the flywheel from ICON is $600 plus. Thats right $100 more than you probably paid for the bike. There used to be businesses that rebuilt the roller clutches for the skiers. There is no rebuild service available for the flywheel on this bike. So if you don't buy the maintenance contract witch will cost you as much as the bike for 4 or 5 years you have a very heavy piece of junk to dispose of. This is planned obsolescence at it's best. If you are very handy. You can disassemble the bike and find a commercial machine shop that can replace the bearing for you. It is sandwiched between roller bearings on each end. You will need a press designed to remove and replace bearings for commercial machinery like conveyor belts and assembly line equipment and someone to order and replace the same or an equivalent bearing. This actually should be a relatively affordable service. At least in comparison the only other option.
Oct 30, 2013 | FreeMotion 350R Recumbent Bike
Hello, People I have a Tunturi 202 rowing machine, and love-it. However, the little wheels under the seat have worn-through ... weep! Can anyone help me on locating replacement wheels for the...
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two!
Mar 10, 2011 | Exercise & Fitness
My brush will not turn, and the brush control is stuck on "off"
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Jul 05, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Worn seat wheels on Tunturi 202 need replacing
Jul 01, 2009 | Tunturi Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
My dryer dries but it shrieks. Do I need to buy a new one? Is it worth it to have it fixed? Thanks!
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through and metal showing
replace both rollers or both felts if one is worn
roolers are bout $9 /pair
felts can be anything the manufacturer thinks they are worth
Aug 28, 2008 | Maytag Dryers
Belts keep burning up
It sounds like you have a roller problem. This machine has a carbon fibre roller suspended on plastic end caps. When dirt and hair etc. gets in and damage the bearings, the belt will be the first thing to go. If the roller is noisy, that indicates that it is off centre and is rotating unevenly. You will probably have to replace the roller.
Take the belt off and rotate the roller slowly and observe the ends. If it is off balance, it will not rotate evenly. The plastic caps unscrew to reveal the brngs and usually you will find hair and other junk gumming up the works. If the roller is damaged, you will be able to see melted plastic and chards of carbon fibre there.
Feb 15, 2008 | Hoover U5172900 Fold Away Widepath Bagless...
Brush roller stopped rolling
My daughters is doing the same thing and the plastic at the ends of the brush bar melted just enough for it not to turn properly. You might want to chech that.
Nov 25, 2007 | Eureka 2961AVZ Bagless Upright Vacuum
Dryers Logo
27 people viewed this question
Top Dryers Experts
