Question about LG Dryers
LG Model DLE1501W - I set the dryer for appropriate cycle. It shuts off after 10-15 mins or so. clothes are still wet.
If I keep repeating this over and over, it will shut off faster the dryer the clothes become. I cannot get it to run long enough to dry thick socks. Dryer is 3 months old and this has just started within the past 2 weeks. Vent line is short and clean.
  • LG Master
  • 2,322 Answers
The moisture sensors seem to be the issue. The two metal bars on the lint filter housing. Try cleaning with alcohol and stop using dryer sheets.
Posted on Dec 18, 2016
  • robert Dec 18, 2016
    I assume this does not happen on a timed cycle
I have a LG dryer model DLE5932W that will not shut off on its own
The cycle timer may be hanging up at the 1-minute point.
Aug 31, 2016 | LG Dryers
Permanent press cycle keeps shutting down and doesn't finish.
Hello. I don't know what make/model dryer you have but the problem could be with load size and type of clothing. The sensor bars are usually located on the front of the lint screen housing(you have to put your head in the dryer and look back to see them--they are 2 metal strips, approx 1/2" apart and at least several inches long). The damp/wet clothing keeps shorting across the strips, telling the main board to keep the dryer running. If there isn't enough of a load, the dryer may think that the clothes are dry prematurely and count down too quickly. The sensor bar technology *is not* an exact science--it works best on large loads with like clothing. For smaller loads, use time dry and adjust the temp setting accordingly. I hope I helped you.
Aug 22, 2015 | Dryers
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
3 BATH TOWELS AND ONE HAND TOWEL WERE NOT DRY AFTER 60 MINUTES IN DRYER . THIS HAS BEEN A PROBLEM SINCE WE BOUGHT DRYER IN MAY. A LOAD OF UNDERWEAR, T SHIRTS AND SWEAT SOCKS ALSO WILL NOT DRY IN AN HOUR...
HI,
If the unit is less than a year, you problem is a restricted vent system and not in the unit either. A simple test would be disconnect the vent from the back of the unit, run the dryer. If your clothes dry faster, your problem is in the vent system. If no improvement, problem is in the dryer. Get back to me and let me know how this goes.
Thanks
Aug 09, 2011 | Maytag MDG2706A Gas Dryer
I have a LG Electric Dryer DLE5932W. When I run it on any of the settings in sensor dry the dryer turns off before the clothes are dry and you have to run it multiple times to get a load dry. Then if you...
this could be operator error please hear me out...... when wash bath towels you also put in wash cloths and hand towels .... there is a sensor in dryer drum shroud in front of lint filter to metal silver strips when the clothes are tumbling they sweep across this sensor telling the dryer heat to stay on and continue to dry.... if th small wash cloth sweeps it first before the bath towel then u get the same results as your describing just like if you were waqshing colors load like cotton tshirt and blue jeans the tshirt is going to dry way faster than blue jeans so if the tshirt sweeps that sensor first the dryer going to shut off we have to sort our clothes to thickness ans same size articles just try it once i bet your clothes are dry when cycle completes
Jan 31, 2011 | LG DLE5932W Electric Dryer
My maytag duet electric dryer is heating, all controls seem fine, we cleaned out the lint traps, checked the hose and blew out vent as well. The dryer keeps shutting off early before clothes are dry. They...
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes.
As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time.
If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Dec 10, 2010 | Dryers
When dryer is in cycle for 40 min. clothes are still wet. Setting are on heavy duty, 40 min. and High heat...
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Nov 27, 2010 | LG DLEX2501 Dryer
Dryers Logo
234 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
