Question about Samsung Refrigerators
Rl39qwbns Samsung fridge freezer keeps shutting down.
  • 3 Answers
SOURCE: Problems with my samsung fridge/freezer SR-L36/SR-L39
is whisker growth like ***** hairs?
Posted on Jun 04, 2008
  • 958 Answers
SOURCE: Samsung SRL551 DP Fridge/Freezer
check the manual for a reset button, or un plug it for 30 minutes then plug it back in.
check also the door switches, they could be malfunctioning, see if the lights are turning off when you press the switch.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
SOURCE: Samsung Fridge can't get temp down
it is probably the door switch. I just pulled the switch from a rb2055 and disassembled the switch. one of the contacts is broken.
If you unplug the fridge and plug it back in, the light should work. push in on the switch button with the door open. If the light does not go out, switch is bad.
pry the switch gently out with screwdriver, unplug it and get a replacement.
If you are watching this I can also probably tell you how to jerry-rig it to run while waiting for replacement swicth.
Posted on Jan 03, 2009
  • 117 Answers
SOURCE: Fridge defrosting
SOME GREAT SAMSUNG DIY REPAIR HELP ...
samsung fridge freezer diy help
Posted on Oct 02, 2010
imufo2
  • 3773 Answers
SOURCE: Samsung side by side fridge/freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
For
extra help go here:
Thanks
for using fixya
Leo Ponder
imufo2
Posted on Aug 17, 2011
My Samsung cooltech freezer and refrigerator keeps freezing all the food in the fridge. It also seems like it is leaking from the freezer into the fridge
turn the temp dial in the fridge down if set on on 5 try 3 and see if that works . there have been some makes that the control has failed and needed replaced .
Mar 02, 2015 | Samsung Refrigerators
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
The fridge keeps leaking water underneath,the freezer part keeps iceing up down the bottom under the draws,the water is the main problem.
Water in the drain overflowing can be the reason for the water spilling,it can be the defrost overflow or the leak from the evaporator tubing's to the drain. So drain off and check perhaps more condensation is the result of the overflow.
The icing can be related to water formation from the food or leak from the evaporator, high frosting can blow the water inside the freezer.
So set the freezer temp a little lower so that the freezer shuts off than to make it run continuously.
Sep 30, 2010 | Samsung Refrigerators
Fridge defrosting
Sounds like the defrost is cycling on and off. The model number is incorrect and I will need a correct model number to help you better. Sea Breeze
Aug 25, 2009 | Samsung Refrigerators
SAMSUNG RS21DCNS
samsung fridge freezer problem
Apr 27, 2009 | Samsung Refrigerators
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Samsung Fridge Freezer Model RS20
Renee,
There are a few things we need to look at. The likely cause is frosting up of the coils. This will also stop the fan. The best thing to do is to defrost the unit completely. The easiest way to do this is to shut it down and leave the doors open for 24-48 hours. You'll have to mop up a surprising amount of water. Now, why did it happen? Probably humidity due to 'window shopping', not closing the doors/bad/dirty gaskets, leaving liquids in the box which are uncovered. If this doesn't fix it...and you'll know after a week or so, it may be that the unit is low on gas or has a defective defrost timer...but that is getting ahead of ourselves.
Jan 22, 2008 | Refrigerators
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
