Question about Garden
Fisher snow plow won't move. the pump seems to work fine. will not lift
  • 4 Answers
SOURCE: i have a 2000 fisher
if it makes klic,klic,klic sound it may be the solenoid relay it cost about $30,try that
Posted on Jan 26, 2009
countrysi248
  • 443 Answers
SOURCE: no air coming through the vents
Sounds like the door that brings in fresh air is not closing enough so when you get to moving it is not letting the cab recirculate the inside air and bringing in some from the outside which comes from the bottom of the windshield on the outside. along with when you get to hitting the gas going down the road you might be loosing a little vacuum and that door going to your vents might close a little.. ? what you thinkin? just a few ideas might not be a fix though thanks Jerry
Posted on Apr 22, 2009
mcgyver468
  • 710 Answers
SOURCE: I just bought a 1986 chevy 1/2 ton with a fisher
PUMP SHAFT MAY HAVE SHEARED OFF THE KEY-WAY. CHECK IT OUT. GOOD LUCK
Posted on Sep 04, 2009
oldmanewtoys
  • 414 Answers
SOURCE: my fisher plow wont move
Sounds like pump is not working, check all fuild lines. Unless the plow is all electric, then the ground
Posted on Feb 26, 2010
SOURCE: Lights on a fisher xtreme plow wont work
Check your harness plug ends for broken pins. Also the isolation module could be defective
Posted on Feb 07, 2012
Boss v plow won't lift. Replaced motor and valve control. Lifted twice and quit. Now what do I do?
Check electrical connections to the Lift Pump. I'm not impressed with Boss's wiring
Jan 13, 2016 | Boss V-XT Poly Snow Plow
The plow wont lift but it will move left to right checked the cennections and eveything seems fine but it wont lift
No fluid in your lift pump or your lift solenoid is bad or orings bad on your spool valve for lift
Dec 29, 2015 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
I can hear my fisher plow motor but the plow will not lift or angle
There solinoids on pump. Check wiring and grounds. Make sure all small wires are intact and in good condition. But most likely there's a loose corroded or green wire causing issue
Jan 09, 2015 | Cars & Trucks
Fisher plow gets power to lights but wont lift or turn, Any ideas?
Fisher needs a good contact loose contact start from the battery and work your way around everywhere theirs a connection
Dec 28, 2012 | Fisher Minute Mount Plow Joystick...
Snow Bear Winch..... Will not pick up plow at times. Motor seems strong drum will not turn,,,slips. Is there a replacement part available without buying an entire winch? Thanks
Hi there, I had the same problem, my winch has a chain to lift the plow.I put oil on the chain to keep from rusting and thats what started my troubles.So I took the mount off that holds the chain on the winch and there's a brass piece that is squeezed behind it.Cleaned and tightened it and works fine now. If you take motor off winch to check gears[ DON'T USE GREASE] when reassembling! When its cold it doesn't want to turn, just use motor oil or spray lube
Jan 19, 2011 | 82" TruckSUV Snow Plow
My fisher plow wont move
Feb 26, 2010 | 1998 Chevrolet C1500
I have a Meyer mod # E-60H. Last year it seemed
You got the idea, because both the motor carbon
brushes and a weak battery is one of the major causes of your problem. So, have a check on these items.
Furthermore, also check the oil as well as the oil filter
if it needs to be replaced. When all the checks are done
and fixed, I'm sure that you will get the best result . Hope this will help you.
Oct 23, 2009 | Plumbing
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
