Question about Home
Can I replace Sylvania Octron F032/741 32W bulbs with LEDs? Fixture is probably 15 years old and has 4 fluorescent strips all burned out in closet.
2 Suggested Answers
mark24354
  • 776 Answers
SOURCE: The acrylic diffuser on the fluorescent fixture in
I recommend you buy a complete new fixture. If you can still find the same model, just install the lens and you are done $100 to $150. If you can't find the exact one, a lithonia lite UFC looks close. They are not difficult to install if you know how to turn off your circuit breaker and turn a screw driver. Price again, $100 to. $ $150 at a big box store. If you order it from a specialty lighting store, you might be able to talk them into free installation since you are paying a premium price. Basically, it will cost the lighting manufacturer the same to produce and ship a new lessor a complete fixture. You may as well save yourself the headache and play the same game as the manufacturer - just buy a whole new unit. Also buy local, these fixtures are not packaged to survive a fedEx shipment. Good luck -mark
Posted on Jun 05, 2011
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
How do I open the fixture box on a fluorescent light
if its an old 2/4 or 8 foot tube light , these used the shade as part of the housing this is where the ballast /starter is located and other wiring is there too , to remove these old type , remove bulbs by gently twisting 1/4 turn and allowing tube ends to drop free(hold on to bulb !!) remove all bulbs this way , then locate the end where you'll see a nut , there's only one on one end , sometimes on fancy decorator lights they make the nut seem as part of the ornation of shade, but a carefull look and you will see the seams that make it removable , unscrew this and shade end will drop away , the trailing end will unhook when shade is aprox 33 degrees angle away from light these old fixtures can be quite heavy so be prepared for weight ! make sure you disconnect any power to light before working on anything inside of it ,including tube ends ,as I find these are whats bad most times (cracks)
Aug 09, 2015 | Home
I need to replace a bulb in ceiling fan.The dead bulb is a 30 Watt Slyvania #FC9T9/DSW/RS I need to know the size as no one carries it.
You should be able to use one of the following as a replacement:
S6505
FC12T9/WW
32W T9 4 Pin Base Warm White Circline Fluorescent Light Bulb
Satco
S6507
FC30/SW FC9T9/SW FCL30LEX
30W T-9 9in 4-Pin
Satco
11085
FC12T9/KB
32W -Bulb: Circline T9 -Base:4-Pin G10q Single-End -
GE
20037
FC12T9/WW/RS
32W -Bulb:Circline T9 -Base:4-Pin
Sylvania
20233
FC12T9/DSW/RP
Sylvania
391227
FC12T9/SOFT WHITE
32W -Bulb:T9 Circline -Base: 4-Pin
Philips
Dec 01, 2014 | Dryers
How to retrofit fluorescent tube with led tube lights
Note:
First, corrosive or solubility chemicals will destroy the protective shell of lamps.
Second, the normal ambient temperature is -20 ° C to 40 ° C, if beyond the scope of this provision, it will make adversely affect on the lifespan of the product.
Third, before installing, do not connect high-voltage power supply, if there is damage to the external of lamp, switching to the engineers with qualifications for the repair and replacement; otherwise,the bulbs can not be replaced; take care of the the discharge of fire and shock.
Replacement Procedures Information:
First, the LED tube is generally a double-ended conductive LED lamp containing professionally designed built-in power supply, which can be directly input voltage AC100-240V,it can be mounted directly on a dedicated LED T8 tube light shelves, do not need to add other drives.
Second, the LED tube can directly replace fluorescent tubes, the user can remove the original fluorescent tubes and install LED tube, then double-check the configuration of lighthouse, following the figure A, B, C three installation diagram for installation.
Third, cut off the power for the installation, repair, maintenance and demolition work to avoid accidents.
Installation Guide:
led-tube-light-installation-instruction.jpgA, connect the power cord on the lighthouse to the external power lines, no need to distinguish neutral wire and line of fire fit with LED lamps , then rotate 90 °,then connect the power to light up.
B, if there is starter on light house , take out the starter, then just repeat the A
For more information about LED tube,just visit www.ledclan.com
May 21, 2014 | Acclaim PIXEL TUBE w/ 15 RGB LEDs
Replaced sylvania 26 w 4 pin in overhead light fixture and it is not working
replace the ballast almost always these lights do not usually burn out the ballasts go bad
Dec 13, 2012 | Lithonia Lighting Fluorescent Flush Mount...
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
Home Logo
21 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
