Question about Car Audio & Video
Marantz CDR-500 CD Recorder Just the playback tray cycles in and out upon power-up. Is there a donor unit that I can get this playback portion with or if the burner fails, what can replace it?
Also, is there a copy of the Service Manual for the CDR-500 that might be available as well? Thanks.
    Top Expert:
  • Car Audio & ... Master
  • 75,025 Answers
It is due to some mechanical failure to the disc loading unit. It can be repaired. A broken gear wheel or a broken rubber belt can cause this. Contact any service technician. There is no need to bu any substitution for this mechanism. If you wish to get some details; check the site linked here. Pull up older posts.
Posted on Dec 14, 2016
Tascam CDR-W5000 CD Recorder won't open the tray (drawer). Please help!
This could be a bad belt or a defective end sense switch. The parts are no longer available I am told for this unit by New Jersey Factory Service where the could be fixed. This is one of the older models.
Dec 06, 2012 | Audio Players & Recorders
I have the Denon CDR-W1500 recorder and the recording side no longer functions. It doesn't have that many hours of use. The tray doesn't recognize a blank cd but both sides will playback discs. Your help...
Your original post said it was blank discs that didn't work.
Now it's ALL discs including pre-recorderd ones. THAT changes things considerably.
Is it audibly rotating the disc once it's loaded?
May 21, 2010 | Denon CDR-M30 CD Recorder
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
CDR tray
it's more than likely the servo board which is fixed under the mechanism.
this is very common but i'm not sure which component fails on the board but i've always got hold of donor recorders and switched the servo boards and all was fine.
Sep 06, 2009 | Marantz CDR500 2-Disc CD Recorder
I recently purchased a used Marantz CDR300 CD Recorder. Everything powers on but when I put a cd in the tray, it doesn't close automatically when I press the close button and when I manually close it, the...
CDR error means the trouble is in the laser eye,maybe the eye is faulty already or dirty. If the laser eye is dirty,then you need to clean it with a cotton buds.Open the unit then wipe the laser eye tenderly with the cotton buds or buy a DVD / CD cleaner kit.Just click this link;
Hope its help:
Jun 27, 2009 | Marantz CDR-300 CD Recorder
Marantz CDR633
Try the following link.The manual will be automatically downloaded once the link is clicked.
click here for the manual of Marantz CDR
Good luck.please do rate my answer if accepted.Also feel free to post further comments.
Jan 18, 2009 | Marantz CDR632 CD Recorder CDR-RW with...
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
Popping sounds in stereo during playback of burned cd's
Is it just the analogue inputsthat do this? Soulnds like a faulty input board.
Sep 16, 2006 | Marantz CDR631 CD Recorder
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
