Question about Plumbing
I own a 1986 kountry aire 5th wheel Trailer I live in it as my home. I've Bypassed holding tanks an hooked up sewage.Do I need the pump for water pressure when stationary an hooked up to city water?
  • 131 Answers
SOURCE: trailer wiring
First check and make sure that the marker lights are working on your pickup. If not, check the fuse. If they are, you will need to make sure the there is power going in to your trailer plug form the brown wire. Then check and make sure you have power through the trailer wire. All of this can be done using a electrical tester you can get from the dollar store.
Posted on Jul 06, 2008
  • 45 Answers
SOURCE: Trailer harness - Red wire has no power
Hi: under the hood in the power distribution box there is a 40 Amp fuse that has to be installed to power up the trailer package. When standing looking from the front left fender it should be at the front right corner, refer to the power distribution diagram on the cover. As well under the box by the spare tire is a plug in type module mounted on the frame. There should be 2 wire harnesses located there, make sure the correct plug in is connected. Hope this helps... please rate suggestion .... ty
Posted on May 22, 2009
  • 10 Answers
SOURCE: water pump
Try cleaning the jet.
Posted on Oct 24, 2009
gtmerkley
  • 190 Answers
SOURCE: 5th wheel that has a plugged toilet
Put a wet vac on the hole that you open to empty the tank and tape it shut so it wont get air in then turn it on and flush the toilet sounds like something got stuck when it got to full if this don't work take stool off take it outside and turn it upside down and use a water hose to flush it out backwards from the outlet hole there may be something stuck in there that your auger cant get out.
Posted on Nov 06, 2009
  • 349 Answers
SOURCE: when adding air to a pressure water pump ,i
Sounds like the bladder is gone or inproper air pressure in water storage tank.
Bladder goes bad check it out with step 1
1-
One way to check for sure with everything hooked up. The air valve on top of the tank if pressed you will get water out of the valve which should be only air. This will let you know it should replaced.
If Tank bladder is low in air and not water coming out.
2-If it checks ok put an air gauge to tank to check the air pressure, with a standard 40 gal tank you will have 28 psi of air in tank for it to function properly.
Posted on May 22, 2010
Where is the water pump on a laredo 274rb located? Its getting cold and time to winterize.
Is 1 gallon such a waste of money or replacing all lines busting from freezing .
Nov 04, 2016 | Keystone 2014 Laredo 274RB
Need to know the location of the shurflo water pump in my 2007 starwood lx 5th wheel trailer
hard question
cant find an internal design layout on that RV
will have wiring and plumbing pipes connected to it
check under removable seats on the sink side
side inspection panel if there is one
older pumps needed to be primed and sometimes lower than the water tank
or close where the water tanks are
Sep 26, 2016 | Cars & Trucks
How to drain fresh water tank on a 2004 Keystone Montana 5th wheel travel trailer Model #2955 RL
Should be a low point drain near the tank fill area underneath the trailer.
Sep 12, 2016 | RVs
When i try to fill the fresh water tank the water runs out a hose under the trailer. Where is a shut off valve?
sad to say this but we have no idea as we see no make model year etc . but can suggest looking the unit over well with a flashlight . under seats in cabinets under sink etc .
Aug 31, 2015 | RVs
Can I pull an 18 foot 1973 Aljo 5th wheel travel trailer with my 2004 Mazda MPV van? My van can pull up to 3500 pounds.
">No, a 5th wheel trailer requires a 5th wheel hitch which is bed mounted, not bumper mounted which is what you have or frame mounted in your case, either way the van cannot tow a 5th wheel due to its design the 5th wheel hitch has no where to be located except in a bed of a truck.
Aug 22, 2013 | Heating & Cooling
Nov 04, 2009 | Plumbing
Locating owners manual for 5th wheel & factory appliances
You'll probably find that the actual owners manual for the trailer is just a generic one, that covers many trailers in the fleetwood line-up. I'm guessing your worried about the AC, microwave, water heater & fridge. Get make & model numbers off them & I'll see what I can come up with. As far as items in the trailer other than that or questions, feel free to get back to me with any, and I should be able to explain most if not all. I'll also keep my eyes open at work (RV dealership) for a manual of your year.
Aug 20, 2009 | Dometic Rooftop RV Air Conditioner
Plumbing Logo
124 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
