Question about Samsung T24C550ND 24" 1080p LED HDTV/Monitor
Samsung tv/monitor turns on when it wants to.Once it is on it works perfectly fine. The standby light is on. It is an issue with getting it on initially. It is plugged directly into the wall outlet.
    Top Expert:
  • Samsung Master
  • 75,581 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Dec 14, 2016
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Sometimes tv won't turn on and standby light blinks and sometimes it works perfect
The key here is the number of blinks of the standby light. This is an internal diagnostic code. Please provvide that count and I should be able to suggest possible fixes.
Thanks,
Dan
Apr 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Flashing red standby light
Take it down from its mount and try to restart it if this resolves the issue your mount is too tight on the back of the lcd monitor.. This happend to me as well good luck with your BRAVIA
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Message that game will not play at current video setting
Hello.
You just need to restore the defaults for the video. Here is how to do this.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps!! Good luck!!
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Once Standby mode shut down Monitor will not operate for a few days
Problem is maybe caused by electrolytic capacitors in PSU you can inspect them visualy if their top is blown then they are defective you can easily replace them.
Good luck.
Nov 14, 2006 | Samsung SyncMaster 173P 17" LCD Monitor
Samsung T24C550ND 24" 1080p LED HDTV/Monitor Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
