Question about Brother Sewing Machines
On brother he2 embroidery machine, how do i set machine, to move only one letter, not both? CP. only move the P down. To the middle of the C?? i am a newby to this machine ??
  • 4 Answers
SOURCE: Using a Brother ULT 2003
The solution is to take it to an authorized Brother dealer. It sounds like either something wrong with your embroidery hoop sensors, or more likely something is wrong with the brain of your sewing machine. Hopefully after all this time you've done just that. I'd hate to think of a ULT just sitting around collecting dust.
Posted on Nov 22, 2008
  • 4 Answers
This is not normal operating behavior for a ULT, take it your a Brother authorized repair center so they can inspect the sensors and the program.
Posted on Nov 23, 2008
talk2ginny
  • 34 Answers
SOURCE: can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.   Cheers, Ginny
Ch
Posted on Feb 12, 2009
  • 46 Answers
SOURCE: I have an brother 8200 embroidery machine and when
If you take the face plate off (left side cover) there is usually a small sensor "lever" that is activated when you raise or lower the presser foot. This could be bad or broken. Many models had plastic then they switched to a metal lever. I think this could be it.
Posted on Aug 05, 2009
  • 980 Answers
SOURCE: SETTING THE TIMING ON DISNEY BROTHER PE-180D EMBROIDERY MACHINE
Email me for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Mar 07, 2010
Testimonial: "although this was very helpful i decided to take it to a shop and let them sort it out thanks for the help"
Do feed dogs drop automatically on SE-400 when embroidery unit is attached?
Yes they should unless the tab on the middle of the embroidery unit is broken.
Jul 31, 2014 | Brother SE-400 Sewing & Embroidery Machine
Embroidery problem
Hai, 1.You should thick and white or blank cover run a letters embroiderys. 2. After don't remove the frame. 3. Put on the embroidery cloth. 4.Marking. 5.Frame setting with smooth needles. 6.Put the frame. 7.Trace the machine after running and finshed the design.
Mar 23, 2014 | Brother SE400 Computerized Sewing and...
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
Clunking noise from sewing machine
Would need a good look to know whats wrong sorry the bad answer but a sowing machine with clonk ?? could be anything
Jul 05, 2013 | Brother HE-1 Embroidery Machine
Black line down middle of LCD screen Brother
the screen will have to be replaced is it under warranty?
Aug 27, 2010 | Brother InnovIs 4000D Computerized Sewing...
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
Feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
Sep 19, 2009 | Brother SE-270D Computerized Sewing...
Bobbin thread shows through fabric ALOT
When this happens you need to adjust the tension down. If it's set at a default of 4 move it down to 3.5 or even down to 3 sew a bit check. Certain threads do this more (Sulky) on the brother than others (Maderia), but the black lettering in the embroidery feature always seems to need adjusted. The tension adjustment is the same for sewing or embroidery mode.
Sep 15, 2008 | Brother ULT2001
Using a Brother ULT 2003 embroidery machine. In the middle of embroidey design if I stop machine the button to restart the machine stays red and I get the msg to "attach the embroidery frame"...
Sep 04, 2008 | Brother ULT2001
Jul 18, 2008 | Brother ULT2001
Sewing Machines Logo
43 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
