The top half of text on several lines of text does not print. The bottom half of this line prints ok. The remaining lines of text are printed normally.
  • 691 Answers
SOURCE: CX6600 horizontally cuts text
The problem may be that you have a clogged nozzle in the print head. Run a nozzle check pattern and check the results. If the pattern printed is broken for any colour, run a head clean. You should also check the print head alignment, as it may have gone askew. I f you do not have the facility to run an alignment check, get hold of the Epson Adjustment software (try and that will do the job for you.
Posted on Jun 18, 2007
  • 837 Answers
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
Posted on Nov 23, 2008
  • 419 Answers
SOURCE: prints complete lines with occasional lines half height of letter
Your printer cogs may be damaged or your paper rollers could be slipping resulting in this "odd" output.
Paper rollers can be cleaned with an appropriate cleaning kit but if the cogs are damaged it's not worth repairing.
Posted on Jan 23, 2009
SOURCE: Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Posted on Aug 17, 2009
  • 990 Answers
SOURCE: printer prints every second line
Hello sir; I believe it's time to clean print head and ink cell, power on the machine open the cover ( as you replace cartridge) , when carriage move to the center , then UNPLUG the power cord. then you may move carriage freely by hand all the way to left, noe you can clean up ink cell easily.
Posted on Sep 25, 2009
Testimonial: "Printer is now working fine. However I had to clean the nozzles a few more times . Thank You for your help."
Why does every other line of print have the top half of the print cut off?
The print head prints two lines of text/image at one time. If there is a partial print of alternating lines, you probably have a partially clogged print head. Print a test page to see what you get, and perform head cleaning process if needed.
Dec 29, 2015 | HP Photosmart 3310 All-In-One InkJet...
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
27 people viewed this question
