Question about Dryers
I have a Brada dryer I purchased about 5 years ago. Now when I turn it on it will run for about two mins and shut off. On the display screen it shows what appears to be an upside down f and a O
Jimster
  • 240 Answers
SOURCE: Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Posted on Feb 15, 2008
SOURCE: Problem with Kenmore Dryer HE2
have you gotten any error codes?
Posted on Nov 05, 2008
MNTECH
  • 1543 Answers
SOURCE: sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Posted on Nov 30, 2008
  • 659 Answers
SOURCE: loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Posted on Apr 10, 2009
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
I have a brada dryer that runs for two minutes then shuts off. It shows a code . I tried my braker switch didn't help. Cleaned it all out and still the same.
Brada Appliances Product Support ' ManualsOnline.com
www.manualsonline.com/support/brada/
Manuals and free owners instruction pdf guides. Find the user manual and the help you need for the products you own at ManualsOnline.
Sep 30, 2015 | Dryers
Dryer runs for few mins the shouts off
Hello David Neal, I appreciate your post!
I see that you are stating your Frigidaire dryer will run for a few minutes and then shut down. It sounds like a potential problem with your control panel or wiring harness. I would seek assistance from a profession technician to come out and properly diagnosis your dryer to avoid any unnecessary part purchases. I hope this information has been helpful. -Matt
Oct 07, 2014 | Frigidaire Dryers
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Kenmore elite 62042 says it is done, but, always requires some more time and seems to be progressing towards longer drying times. the clothes are warm but still damp. started 6-12 mos. ago, 5-10 min extra...
Here are a few more things to look at:
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Dec 19, 2009 | Dryers
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
Sensor dry timer problem
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
