Question about Dryers
I have a Brada dryer. When I turn it on it will run for about two minutes then shut off and show on the display what appears to be an upside down letter f and a 0. Any ideas what to do?
SOURCE: lcd display is upside down
here is the answer: hold down the "MODE" button while a DVD is playing. http://polaroid.custhelp.com/cgi-bin/polaroid.cfg/php/enduser/std_adp.php?p_faqid=2863&p_created=1123860923&p_sid=-SRglRFi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9NDoyJnBfcm93X2NudD0zNCZwX3Byb2RzPTIyOCwzNjksNDQ4LDQ1MyZwX2NhdHM9MCZwX3B2PTQuNDUzJnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTI*&p_li=&p_topview=1
Posted on Jul 05, 2007
  • 6 Answers
SOURCE: UPSIDE DOWN DISPLAY SCREEN
http://www.dxgusa.com/Support/downloads.html
Posted on Jan 22, 2008
proton77
  • 1183 Answers
SOURCE: My DELL Monitor shows the picture upside down
Try holding down the CTRL key + ALT key and tap on the Up arrow key once to rotate the display back to orginal orientation
Thanks
proton
Posted on Mar 22, 2009
SOURCE: It shuts down after a few minutes and E1 appears
how to slove this problem
Posted on Aug 11, 2009
SOURCE: media error 0 shut down displays when unit is
while the machine is off mode, hold down track edit and shutdown buttons. then power on while holding these buttons. an option to to reset will come up, let go of the buttons and select "yes".
This will reformat your entire hard drive, and you will lose any music you were working on, but it becomes operational again. Or you can send it in to Tascam and let them try to bring it back, if you don't want to lose any material.
Hope this helps :)
-Chenoa Desiree
Posted on Feb 25, 2011
Shows code upside down f and a 3
Take a look at these codes and see if any look similar.
Sometimes the digital read-out looks different from printed type.
Down on the page there is a link to explore older codes Samsung Washing Machine Errors eHow
Dec 18, 2015 | Samsung WF419AAW Front Load Washer
I have a brada dryer that runs for two minutes then shuts off. It shows a code . I tried my braker switch didn't help. Cleaned it all out and still the same.
Brada Appliances Product Support ' ManualsOnline.com
www.manualsonline.com/support/brada/
Manuals and free owners instruction pdf guides. Find the user manual and the help you need for the products you own at ManualsOnline.
Sep 30, 2015 | Dryers
Dryer completely shuts off after about 15 minutes. Cannot turn the dryer back on for about an after
SORRY TO HAVE TO TELL YOU BUT Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
When I start my dryer it runs for about 2 minutes then shuts off showing 00 minutes remaining
You may have a faulty timer, or a safety limit is shutting down the dryer because it is heating up. How long do you have to wait before you can turn it back on after it goes off?
Jan 24, 2013 | Dryers
I have an Amana NED7200TW dryer that is approx. 2 1/2 years old and am having issues. The first sign of a problem was it would not come back on after running a 40-50 minute cycle. Nothing would come on,...
Open the cabinet and look for lint buildup around the motor. Lint will act like a blanket and hold to heat in on the motor which in turn will cause it to shut down by way of it's safety mechanism. Check that out and post back your findings.
Oct 16, 2012 | Amana NED7200TW Electric Dryer
When I load my clothes into the dryer and turn it on it runs for approx a minute to a minute and half then shuts down and starts flashing pf on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 18, 2010 | Kenmore Elite Oasis ST 6806 Electric Dryer
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
