Question about Poulan Garden
Change throttle cable on poulan pro 22042cc chainsaw.show video
SOURCE: poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Posted on Oct 27, 2008
SOURCE: Poulan Pro Clutch Removal
Yes there is a special tool to engage on the clutch. You can get it from the Poulan web site - I think it is part number 31112 - cost about $5. Maybe you can get by without it, by using a screwdriver and hammer, but the tool was easy and risk free. You also have to stop the piston, as the previous poster said. I Googled how to do this, and the consensus seemed to be that it's easiest to stick rope down inside the cylinder, avoiding pusing it through the exhaust port. That worked like a charm. I used a hammer to hit a wrench on the clutch tool to break it loose.
Many thanks to the original answerer for getting me on the track to solving this.
Posted on Dec 17, 2008
slohry
  • 87 Answers
SOURCE: how to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Posted on Apr 09, 2009
  • 25 Answers
SOURCE: Where can I download a free manual for Poulan Pro
Assuming it's prior to 2007 model year: http://www.poulanpro.com/node5782.aspx User manuals, middle of page: http://www.poulanpro.com/node4041.aspx
Posted on Jul 16, 2009
dontbother10
  • 2220 Answers
SOURCE: lost my manual for my poulan pro 255 chainsaw the
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Posted on Feb 15, 2010
Testimonial: "thank you very much for the information that you sent me. i spent two hours on a dial up modem trying to find the part and 20 seconds to read your rep"
Show video on how to change my throttle cable on a poulan pro 22. 42cc chainsaw
as of now there seems to be no video available for your request
Dec 14, 2016 | Poulan Garden
How to change throttle cable on a poulan pro 220 42cc chainsaw
I would abuse you to talk to a local small engine repair business and see if they will help you make the video. Other than that take the thing apart while using a vid camera. Manuals are not hard to come by.
Or send me the chainsaw and I will video the repair. As long as you pay for parts and shipping I will do it for free. Quazi.moto@yahoo.com
Model pp4218 throttle stuck open
I assume you are referring to a pullen pro chain saw. If so, the cable that links from the trigger to the carburetor is stuck. This can happen due to trash and dirt stuck in the trigger area, or the carburetor needs cleaning. Or the cable or wire to the carburetor is bent. See if the connection between the trigger and carb moves freely when not running.
May 02, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i replace fuel lines?
Where do the fuel and primer lines go in Craftsman or Poulan Chainsaw
Hope this helps. Also try to avoid using gasoline with ethanol. This causes the lines to deteriate.
Apr 30, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How does throttle cable attach in handle
You have to use your finger to compress the throttle and place the steel arm in the hole in the side of it
Aug 26, 2014 | Poulan 295 Pro Chainsaws
I have a 18 in poulan pro that want run. has new plug, air filter,gas filter
Check if is any "spark" at the spark plug.If not change the "coil" =spark plug cable and coil all are together.
Nov 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How does the throttle cable route on a poulan pro 260 42 cc chain saw
HOW DO I INSTALL AN ACCELERATOR CABLE ON MY 260 PRO POULAN CHAIN SAW?
Oct 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
