Where can I purchase a control panel for a Rinaai 606a Silent Servant ventless heater?
5 Suggested Answers
hiltonjug
  • 612 Answers
SOURCE: I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Posted on Oct 17, 2009
  • 53 Answers
SOURCE: I have a Rinnai 506 silent servant vent free
yes you can, but is complicated, involves changing injector, burner, and reprogramming the PCB for the new gas type. Get a pro to do it for you
Posted on Dec 05, 2009
  • 120 Answers
SOURCE: Rinnai RCE-606A vent free space heater, the Lock
Hold the lock button down for approximately one second to switch between locked and unlock. If it is locked when you turn it on you will need to do this first
Posted on Jul 30, 2010
shastalaker7
  • 1515 Answers
SOURCE: I have a smell that
Hi David, this sounds to me like an internal problem with incomplete combustion, and this is why you have this continuing smell, as the fuel is not being completely burned off. Even with the main and secondary filters on this type of heater, they can and will pick up matter and cause this type of problem. These are very dependable heaters, and very much worth it to have it serviced by a shop that is near you that can work on this type of heater. To be honest with you, if you are still smelling this petrol, something is not working properly, so I would take it in for a deeper service. After getting this minor problem solved, it is very important to continue to clean the filters as most people will not take the time until they loose all operation and wonder why? So, yes if you can take it in this I recommend, as I am not on site to help you trouble shoot it properly. But, the problem is incomplete combustion due to an obstruction of some king, and with these fumes I wouldn't want you to have what we call is delayed combustion which is not good! I hope this has been of help to you David, and please keep me posted.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Jan 12, 2011
Rinnai 606a manuel
Rinnai 606a manuel Google Search ..goto this link and see if you find your manual
Dec 02, 2016 | Rinnai Heating & Cooling
Silent servant convector vent -free space heater
I would never blow out a gas heater with a compressor... It is too powerful and you could have damaged something inside.
I would get it checked by a gas fitter.
Mar 12, 2013 | Rinnai Toyostove Direct Vent Heater:...
I have a ventless heater, my house is covered in black soot, i also have a carbon minoxide detector it's never went off, what is it?
Your ventless appliance probably needs cleaned-the combustion burners and air passages need blown out with compressed air or vacuumed. also ensure you have supply of outside air into your house. if your house is sealed up pretty tight you need to crack a couple windows to let air in. There is no such thing as a truely "ventless"..what they mean is ..properly maintained and operated ventless heaters with proper ventilation are safe to use inside. also be aware that other chemicals in the air of your house from candles and air freshners, cleaning agents, etc will burn in the ventless heaters creating toxic pollution.
Oct 03, 2010 | Fahrenheat Electric Convector Baseboard...
Mar 13, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I have a Rinnai 506 silent servant vent free propane heater, can I switch it for use with Natural Gas?
Nov 30, 2009 | Rinnai Vent Free Gas Heater/
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
May 12, 2009 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Rinaai LP space heater will not shut off when set temp is reached
Test the thermistor by using an ice cube. Place the cube on the thermistor and see if the unit starts. Then using a warm towel, wrap the thermistor ans see if it stops. Watch the display to see if it is registering the changes in temp. I suspect a bad thermistor.
Jan 02, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
