Question about The Computers & Internet
Does anybody know how to get SharePoint to work faster? Right know it is extremely slow and we are looking for a solution for this problem. Is it related to the SQL server or is it some UX/UI issue?
    New Friend:
Have you tried fixing default settings on the SQL Server side? Most problems with speed result from incremental autgrowth settings and bad indexing. If you fix SQL parameters and it still works slowly, then I would recommend getting a professional assistance http://www.digdes.com/services/sharepoint-optimization (just in case). Hope that helps. Good Luck
Posted on Dec 15, 2016
dbarchitect
  • 150 Answers
SOURCE: SQL server won't work on my laptop
Two ways to access your server. First, make sure the SQL Server Service is running. Start | Run | Services.msc | Enter. Look for Microsoft SQL Server Service and that it's running. Or Look for the SQL Service Broker icon by the clock and see that it's running. The default instance of SQL Server uses the Hostname. Start | Run | Cmd | Enter. The type hostname. This will be the name to access to server. Then type IPCONFIG, this is then the IP address that you could also use to access it.
SQL Server runs on port 1433, so any firewall has to have it open.
Open Query Analyzer, type in the hostname or ip of the local box, type in "sa" and the password for sa (if setup in mixed mode) or Windows Authentication.
Once you login in, you should now see the databases in the Tree on the left side under the Server | Databases node.
Your description though states "SQL Server won't work on my laptop". TO answer this, the only two SQL Editions that work on anything other than "SERVER" software is SQL Professional and SQL Developer. All others have to be on a "SERVER" platform.
Posted on Nov 24, 2007
SOURCE: sql server
i want to download SQL sever 2000 from net..
How can it be possible?
Posted on Oct 18, 2008
  • 7 Answers
SOURCE: Downloading Microsoft SQL Server 2005
http://go.microsoft.com/fwlink/?linkid=83387
try this or
http://www.microsoft.com/Sqlserver/2005/en/us/express-down.aspx
Posted on Jun 30, 2009
  • 32 Answers
SOURCE: The software does not eve
This is a tougher one! Sometimes when you open the software too fast before thedatabase starts up, you get this. Make sure the SQL Server services are running in Windows before opening RPE
Posted on Jun 07, 2011
gabibacker
SOURCE: SQL SERVER 2000
Hi..U can get info here:
https://groups.google.com/forum/?hl=en#!topic/sql-mdf-viewer/ocCTaFcKYag
Or do this
· Click the Windows "Start" button and enter "cmd" into the text box. Press "Enter" to open your command line utility.
·Type the following command into the command prompt and press "Enter":
cd C:\Program Files\Microsoft SQL Server\100\Setup Bootstrap\Release
This points the command prompt to the location of the rebuild executable files.
·Type the following text into the command line and press "Enter":
Setup.Exe /Action=RebuildDatabase /InstanceName=MSSQLSERVER /SqlSysAdminAccounts=Admin
This command rebuilds the database. It may take several minutes to complete. Once it is finished, the command line returns a success message.
if nothing helped:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/569-i-have-a-problem-how-do-i-fix-a-corrupted-database-file
Posted on Dec 03, 2014
The company is looking into scanning objects from our HP M3027mfp printer onto MS Sharepoint, and so far we're unsuccessful in our research, if anyone knows how, I would greatly appreciate their help. ...
There are a lot of scanning tools which can integrate with Sharepoint. You can find them in http://scanningwithsharepoint.wordpress.com/ . You can scan your document and send it to your sharepoint library with these tools.
Mar 02, 2011 | HP LaserJet M3027 MFP Printer
Ice maker is extremely slow. it will take days to
change the cooling contro indicator to freezer max ..... that will increase the speed of cooling in ur freezer ....
Jan 03, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
I need to find an alternative to Sharepoint
Now that the 2016 on-premises and cloud versions were released, I'm sure there's no need to look for a replacement for Sharepoint, especially with this new Linked Table Manager feature. It allows you to manage complex Access data easily.
In order to import Access spreadsheets, you should follow these steps:
1. locate the address of the site where the spreadsheets you need to import are situated
2. identify the data you want to be imported. You have an option to choose either to import the whole list or just a view, but remember that while you can copy several lists, you can copy only one view of it.
Looking for specialists to optimize your product to the latest version or migrate to Office 365? The "Digital Design" (http://www.digdes.com/) software development team will help you with it. It is a company with solid expertise in Sharepoint services and impressive clientele. Check out its website Digital Design
Jun 04, 2009 | Microsoft Office SharePoint Server 2007...
Slow fan on Window Air conditioner Sears 106.73220
if the motor seems like its getting extremely hot it could possibly be seezing up. i would suggest taking your volate reading for the motor and check for proper voltage, also check you amp draw on the motor. the proper amp draw should be on the name plat of the motor. any below the proper amp draw, replace the motor.
Apr 23, 2009 | Heating & Cooling
Installation of MS SharePoint 2007 in Dell Inspiron 1525 Laptop
SInce SharePoint Services 3.0 and SharePoint Server 2007 does require a server interface to run the collaboration tools you are unfortunately stuck with running it on server software. But all is not doom and gloom as there is an option for you to run Microsoft's Virtual PC. Here is an article on how it works from Microsoft. (http://windowshelp.microsoft.com/Windows/en-US/Help/97a74f0e-798d-45ff-b9bf-7feed68c40e51033.mspx) . This allows you to not ony run your native Operating system, but also run SharePoint on th esame machine in a virtual environment.
Jan 09, 2009 | Dell Inspiron 1525 Laptop
How to move contents from computer default hard drive to external iOmega hard drive, to make computer faster
There is a program on the xp cd called Fastwiz- it will save all your profile data for you. Unfortunately it's REALLY slow and you would be better doing it by hand. If you want to do it by hand you will need to copy all the data in the Documents and settings folder for all the profiles, plus any other data that you will need to reload the drivers. I recommend saving the e-machines drivers directory.
Wiping and reloading the operating system is the best way to resolve problems with a slow system, and a faster bigger newer hard drive is a good idea too. E-machines have a tendency to just die after a year- be aware that you get what you pay for. Also adding more ram to this system will help too.
Dec 02, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Speed of CF vs SD in Axim
The reason CF COULD be faster is that it is a parallel connection (16bit IIRC) while SD/MMC is serial in nature. Now, assuming the INTERFACE were the limiting factor in the speed this could become significant. Unfortunately the interface is NOT the limit (in most cases), the limit is the actual fetching of data from the memory itself. Being Flash it is nowhere near as fast as some of the other types of memory we are used to. It is especially slow when being written to. Newer cards out there are faster then older ones, but in the end I doubt you would notice much if any difference between the speed of a CF versus an SD/MMC card
Sep 14, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
