Question about Home
My Triton shower kept cutting out on normal setting so thought it was overheating as it was ok on economy setting. Replaced with new Triton shower but having same problem with cutting out.
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 34 Answers
SOURCE: triton t80i water only warm in winter
That sounds like a water heater problem, wheres the heater at in your home. If it is effected by the outside weather i.e. the heater is in a cold environment then it would effect the hot water output. try turning up the thermostat on the heater if it is gas then it should be knob on the outside if it is electric you will need to remove the top or the bottom cover and adjust it with a screw driver. If this does not work the let me know and we try some other things. With the weather/temp outside effecting the water temp in the shower then I have a hard time believing it is the shower its self.
Posted on Feb 06, 2009
SOURCE: My Triton Millenium shower just
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Posted on Jan 24, 2011
ZJLimited
  • 17970 Answers
SOURCE: my triton topaz t100si (10.5kw)
If there is no heat at all then you may have a faulty TCO (Thermal Cut Out). A faulty TCO will have no continuity across the two terminals (the black thing on top of the heating tank).
Therefore a good TCO will have power at both connections and a faulty TCO will have power at only one (the function of the TCO is, if the water over heats it cuts the power off to the elements). Here could see one video about some tests...
If there is some heat then It may be a faulty element in the heating tank (there are two, three in most 10kw showers) you can check them with a multi meter you should have a reading of around 12>18 ohms.
If you have power to the elements and no heat it's probably the elements, no power to the elements then it's probably a micro switch.
Hope this helps.
Posted on Apr 28, 2011
SOURCE: My Triton (Jade) electric shower has abruptly
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Posted on May 06, 2011
Water flows continuosly for 1minute after switched off
You need to check all valves, one of them must be broken or too old.
Also the pressure is a little bit higher in there, but there is nothing to be afraid of.
CIAO
May 05, 2011 | Home
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
Jan 10, 2011 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
Stew.
Apr 05, 2010 | Home
Triton jade 2 shower not generating sufficient heat
your element needs de caling i suspect
Nov 11, 2009 | Home
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Cannot locate the thermal cut out in the shower unit
Most of the time, these are an auto reset type. But I would recommend calling the manufacture. They usually have an 800 number for you to call. Or you might be able to find the info on their website and or possibly download the installation and user manual for it.
Mar 30, 2009 | Home
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
I have a Triton topaz 100i shower, recently the water would not heat up, when i opened it the thermal cut out was in pieces, i have now replaced this, but now, no water comes out at all. If i short the...
its the thermal cut-out... when there is something like limescale that causes the temp to get over 50c - the thermal cut out is
activated... it has to be replaced... which u can buy it from triton or get an engineer out to replace it
tip... make sure u clean the shower and shower heads often with a limescale remover....
Apr 22, 2008 | Heating & Cooling
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
71 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
