Question about Dell Computers & Internet
Where is the power button on the dell optiplex 760 mini tower
    Sergeant:
  • Dell Expert
  • 276 Answers
Front right there is a wide cable connected to board with front face plate.
pls check is this match
http://imgur.com/E3320RK
Posted on Dec 14, 2016
MDoe
  • 156 Answers
SOURCE: Dell Optiplex GX260 Tower flashing yellow power button
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Posted on Mar 27, 2008
gherna1
  • 190 Answers
SOURCE: dell optiplex 760 won't go into safe mode
It sounds as though your PF keys are disabled by the BIOS settings. Try this:
Upon cold start or reboot get to the BIOS setup. You may have to press F2 or delete, or whatever key the first POST messages instruct you to use. Different BIOS manufacturers use different keys, and you have to be quick to interrupt the boot process using the correct key. If you fail to determine what key it is, reboot once again, until you see/read what key does the job.
Next, once you're into the setup screens, look for a section where you can set/deny access to the F8, F9, F10 etc keys during the boot process.
Make sure you ENABLE them, following the instructions on what keys to use to set/reset these choices. Make sure you SAVE AND EXIT.
On the next reboot, upon the disappearance of all POST messages, make sure you press the F8 key repeatedly until you see your OS boot options menu, among which you'll find Safe Mode.
Posted on Aug 24, 2009
  • 3940 Answers
SOURCE: Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Posted on Feb 09, 2010
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
orange light indicator on the mother, replace power supply, same problem
Posted on Sep 30, 2010
Where does a dial up modem go in a Dell optiplex 760?
The dial-up modem would install inside the computer in a PCI slot. VERY easy to install but a couple considerations before doing so... There are different sizes depending on whether the OptiPlex is a mini-tower or small form factor case. Also - you would need drivers for the modem that are compatible with the operating system you have installed on the computer.
Apr 28, 2014 | Dell OptiPlex 760 MT Desktop Computer
Dell optiplex mini tower wont turn on
Make sure the power is being supplied from a working source, then check if the switch on the bottom-back of the computer is switched on. If the power button still doesn't work, try holding the button down for 10 seconds. Next, try switching the switch off, unplugging the computer for at least 30 seconds, plugging it back in, switching the switch back on, and pressing the button.
Apr 25, 2014 | Dell Studio Mini-Tower Desktop Computer
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
Dell optiplex 760 power button
Not surer what your question i, but...You can program your "Power Button" to do a lot of things or even nothing.
To program go to "Control Panel" "Hardware and Sounds" then select "Power Options".
Hope this helps.
Jul 09, 2012 | Dell OptiPlex 760 PC Desktop
Opetiplex 760 mini tower how to Open to install extra network card
There should be a sliding latch on the top that pops up one of the side panels.
Feb 21, 2011 | Dell OptiPlex 760 MT Desktop Computer
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
Dell optiplex 210l mini-tower video card upgrade
Before upgrading a video card, it's strongly recommended to check the wattage specification of the power supply unit. If the installed power supply unit can cater the need of the newly installed video card then it can be used normally.
You may refer to the user manual of the Computer to check the wattage specification or the Power supply unit(PSU) or directly open the tower to check for the printed value on the PSU itself.
Oct 01, 2009 | ASUS Computers & Internet
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
35 people viewed this question
Alun Cox
