Question about Car Audio & Video
DOSE ANYONE KNOW THE CHIP ON THE SHARP 3 CD CHANGER CIRCUIBOARD IVE SENT A PHOTO CAN YOU HELP
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
Clearercape
  • 38 Answers
SOURCE: photo transfer
When you connect your phone to the mac via the USB does the phone appear on your desktop?
If the phone does mount on the desktop the easiest way to get them on and manage them is with iphoto (or ilife if installed) use the app to import the files. When importing find the phone and look for the images folder.
The manual way.
The mac should pick up most phones and see them as a hard drive. If it does mount on the desk top you can then open the drive and find the images. They are usually in the picture or image folder.
If you cannot see the drive on your desktop and you have bluetooth on your mac. you could transfer the images via bluetooth. Slower but they will get there. You'll just have to pair the devices.
As 'git1' said. If all that fails you'll need to let us know what make the phone is.
Posted on Oct 02, 2008
SOURCE: CD's are skipping when playing
Sounds like the laser lens is dirty or out of focus. You can take it apart and try cleaning the lens with a soft cloth and see it that works. If the focus is out of adjustment, that takes alot of patience and time. Never look directly at the laser with the case open. On the bottom or side of the laser lens, there are two small box looking gadgets about 1/4" square with tiny screw type adjusters in the center of them. These are potentiometers, they can develop dirty or burned spots over a period of time. Turning them slightly can give you better performance. If I remember right, one of the pots is for width and the other for height of the laser focus. You can identify them by the small ribbon cables that run to them. Try a very small turn on one and try playing the dvd. Mark with a marker a straight line across the pot and board to know where you started, believe me it helps. This can take quite a while and may or may not work. I find this to be the biggest fault with most dvd and cd players. I have fixed many this way. By the way, I use a jewelers screwdriver. They have small plastic ones for these, but they are hard to come by. Good luck.
Posted on Dec 17, 2008
  • 4 Answers
SOURCE: sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Posted on Feb 05, 2009
  • 59 Answers
SOURCE: how do you un-stick a cd from a 3 cd changer
Unscrew the top of the unit and then you should be able to access the cd that is stuck. Then you might have to play with it to get the CD out of the reader.
Posted on May 02, 2009
Sl-eh790 compactdusc changer
Have you opened the case?
Inside the actual cd drive unit there should be a couple of small rubberband like belts. You can try replacing them.
It may help.
If that doesn't work ,it may be time for a replacement.
I have a tendancy to hang on to old audio equipment long after it should have been replaced. It's just hard to let them go!
Good luck with it!
Mar 23, 2014 | Technics Audio Players & Recorders
I think there's something missing on my bmw x5 audio left boot panel
Someone may have put a custom radio in it and then put the PEM one back when it was sold. You should go to a dealer and see if they will copy the diagram for the wiring for you.
Jun 11, 2017 | Car Audio & Video
Power button dose not work
generally its cheaper to buy a whole new reciever than to buy just the face plate as they are not manufactured as seperate components.
Jun 19, 2010 | Clarion DXZ835MP RB AM/FM/CD/MP3/WMA...
The cd changer wont turn on
Take a photo your cd changer, and send me. Maybe i can help for you. My e-mail : info@headunit-repair.co.uk
May 03, 2010 | JVC 12 DISC CD CHANGER MP3 CD TEXT
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Apr 09, 2008 | Sharp XL-HP515 CD Shelf System
Blaupunkt IDC-A09 5-Disc CD Changer
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Nov 06, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
