Question about Refrigerators
OK to make smoothies using ice cubes wedges? blending or grinding base?
kakee
  • 1268 Answers
SOURCE: Jennair JCD2389GES Ice Maker Problem It
Try to do a hard reset. Turn off the unit and unplug the power cable for several hours like 3-4 hours then check if that fixes it.
Posted on Sep 07, 2008
  • 10865 Answers
SOURCE: 25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Posted on Aug 16, 2009
  • 16 Answers
SOURCE: Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Posted on Oct 11, 2009
kvhappliance
  • 218 Answers
SOURCE: rf267abrs only 14 cubes of ice in 1 day
I would give it a few more days most icemakers will not cycle if the temp around the icemaker are above 15 degrees F.Leave the door closed.Open door for even one minute can take a while for freezer to cool off to temps around 10 or colder. Also if you do not have much in there it may be a problem as well it is harder for freezer to cool open space. If I can help with anything else please let me know.
Posted on Apr 08, 2010
spyder301975
  • 99 Answers
SOURCE: Kenmore coldspot icemaker producing hollow ice cubes and the base of the fan area in the freezer is frosting
Check water pressure, low pressure will cause hollow ice.
Posted on Aug 21, 2012
Recepies for the cactus smoothie
Some of the names of cactus smoothies are:
a. Detox Cactus Smoothie
b. Pineapple Cactus Smoothie
c. Cactus Pear Green Smoothie
d. Nopal Cactus Smoothie, etc
Nov 29, 2016 | Blenders
Freezing fresh strawberries
yes. seal them in a ziplock bag or container first
Mar 29, 2014 | Cooking
wash. take off stems cut them into halves or quarters , place into zip lock bags or a sealed container. pop into freezer. easy !
you can blend them and put into a ice cube tray as a great way to add flavour to a fruit smoothie - keeps it cold without watering it down.
Mar 25, 2014 | Cooking
I froze some fresh strawberries to use in smoothies, but upon taking them from freezer, I notice that they small horrible! What's going on?
i just usually wash, take off stems cut them into halves or quarters , place into zip lock bags or a sealed container. pop into freezer. easy !
Mar 14, 2014 | Cooking
How do you make mint ice cubes? I heard that mint doesnot freeze very well.
You can just put mint leaves into the base of ice cube trays and add water and freeze. Because mint is a very soft herb, some people find that it doesn't freeze so well. Another option is to blend the mint in a processor and freeze it in cubes ready blended. This is good for recipes that call for finely chopped or minced herbs rather than whole leaves.
Feb 18, 2013 | Home
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
Pieces of white plastic in my crushed ice
check the ice maker,the base rots out where the water forms into ice cubes or check the tray and the auger to see if a part of it broke off and is grinding up with the ice cubes
Sep 25, 2010 | LG LFX23961ST Stainless Steel Bottom...
How to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Machine does not blend at ALL .
I have had great luck talking to Back to Basics - here is their info...if it is new- should be under warranty.
" One of our customer service representatives will respond as soon as possible. To register your product, please click here. If you need immediate assistance, please call us at 866-290-1851. "
Best of luck,
BB
Jun 09, 2008 | Back to Basics 700 Smoothie Pro Work Top...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
