Question about Car Audio & Video
I NEED THE NAME OF CHIP AND ITS CODE SO I CAN FIX THE POWER ON MY SHARP 3 CD ROTARY CHANGER THANKS
SOURCE: CD problem in Sharp Micro Component Shelf system XL-HP515
Compra un disco limpiador de lentes laser y puede que esto solucione tu problema ya que puede ser solo suciedad en el lente.
Posted on Apr 09, 2008
SOURCE: 98 Isuzu Rodeo 6 CD
After reading about a similar solution from another person, I gently inserted and removed a flat, piece of plastic partially in the CD slot, and out popped my 1st CD. I pushed the button for the next CD, inserted the plastic briefly, and the next CD came out. Got them all out the same way. It was almost too easy :)
Posted on Aug 08, 2008
adamncc1701
  • 158 Answers
SOURCE: I have the Phillips/Magnavox 3
without the model number i cant be exact, but if memory serves me you either hold down the demo or display switch for about 5 or 6 seconds
Posted on Sep 07, 2010
SOURCE: Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
Posted on Jan 08, 2011
gopakumarg43
  • 74383 Answers
SOURCE: Hello. Can you email me the service manual for the Bose 5 cd changer? Do you also have a service manual for the 3 cd changer? Thanks. Rick ricknick53@yahoo.com
I've send service manuals to you a few while ago. Check them.
Posted on Jun 03, 2012
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
2005 Expedition - Changed battery and Cd changer won't work now, is there a fix?
I am not familiar with the 2005 Expedition CD changer, but many of the higher end devices require a code to be entered when the power is disconnected. This helps reduce the theft of car audio equipment since it can not be used again until the correct code is entered. Ford dealership can either enter the code for you or look up the code if you do not have the original manual for the CD changer which should have the code written somewhere in the first couple of pages.
Aug 19, 2012 | 2005 Ford Expedition
My model is one pictured on your "Ask a Question".
quick-start guide:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/
Audio/QuickGuide/Archive/aud_qguide_cddd4500.pdf
operation manual:
Audio/Manuals/Archive/aud_man_cddd4500.pdf
Apr 28, 2011 | Sharp CD-DD4500 System
I have the Phillips/Magnavox 3 CD Rotary Changer System and when I try to power down, it shuts off for a few seconds and then goes into Demo mode. How do I power off completely?
Sep 07, 2010 | Audio Players & Recorders
MS3100 3-Disc CD Changer not recognizing CD's.
the laser on the optical pickup is not able to read the disk. either the disk is scratched (or dirty), the lens is dirty, or the optical pickup is bad and needs to be replaced. to clean, get a lens cleaner at any electronics store and follow their instructions. if it's really bad, unplug the unit, remove the cover, locate the lens, and use an alcohol pad or rubbing alcohol and a q-tip. don't soak it, but wipe the lens off gently and blow on it to dry it off (the alcohol will evaporate). this is not a recommended solution if you are the least bit unsure of what you are doing. if you need to replace it, try www.mcmelectronics.com
Dec 22, 2009 | Emerson MS3100 3-Disc CD Changer
CD Changer not reading CDs
2000 bmw 528i,my cd changer also reads no cds,this seem to be a common problem with all bmw cd changer.Anyway i removed the cd changer from my car,took the outside black cover apart only to see that a white big wheel came of its place,(its the wheel that holds the cd in place from the top (bottom wheel is black attached directly to the motor,as the cd is sandwitched between the black,and white wheels) .if that wheel is out of place the cd will not turn inside the changer for the eye to read it,so your radio screen will read NO CD OR NO DISC.Very easy fix,just place the wheel in its place,and everything worked fine,it took me 20 minutes to fix.
p.s :
1- you do need to make sure you have an original cd in for testing it.
2- you do not need to recode your cd changer at the dealer if you have an old bmw,dealer will need to recode cd changers for 2006 and up.
Good luck.
Jun 15, 2009 | 2001 BMW 3 Series
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
