Question about Stiebel Eltron Water Heaters
Where is the reset button of stiebel eltron dhc tankless water heater?
4 Suggested Answers
  • 234 Answers
SOURCE: Sensor broken - E 71 - Stiebel Eltron WPF water-water heat pump.
I would check the connect first may sure it is not loose.
Posted on Mar 14, 2009
SOURCE: The water heater "Stiebel Eltron
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the problems associated with your model.
I believe they offer a refund if the 'fix' doesn't work.
The manual might also have troubleshooting.
Each day I see 20-25 unanswered questions about tankless water heaters.
And the day before, there were same number of unanswered questions about tankless products.
The number of questions shows the complexity of the machines, the brand-specific-ness of the problems, and the inability of the manufactures to take care of their customers.
If I understand correctly, the manufacturer will refer you to the installer.
There are not many ways a do-it-yourself-er can fix a tankless.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Posted on Oct 31, 2010
guitarmanjoe
  • 336 Answers
SOURCE: heating unit in a stiebel eltron electric instant hot water heater went bad and I have to replace the unit. How difficult is that?
You will have to drain the tank, make sure when doing this to OPEN the pop off valve, the little handle on the drain pipe, or the water will not drain.
Posted on Feb 21, 2013
How do i fix my stiebel eltron tankless electric water heater?It stop working..
Th easy fix would be installing a new heating element that has burned out. You don't say what size this tankless heater but if it stopped working entirely you might have just one heating element inside. You can test it by (1) turning off the circuit serving the heater, disconnecting one of the wires to the heating element, then taking an ohmmeter to see what the resistance of the element is. If it is "infinity" then it is open and burned out. Replace element. If it is around 6 ohms (for a 10kW heater running at 240V) then the heating element is OK. Unfortunately those heating elements don't last forever. Check the repair manual on how to replace the heating element.
Dec 07, 2014 | Stiebel Eltron DHC Instant Tankless...
Leaking
I would continue to push it, hoping it would clear itself. You have nothing to lose.
Nov 27, 2013 | Stiebel Eltron DHC-3-1 Tankless Electric...
Stiebel Eltron 221094
Stiebel eltron model 221094 hot water is not as hot as it was before,
only warm water coming through. Do I need to replace unit?
Oct 05, 2013 | Stiebel Eltron DHC 10-2 Electric Tankless...
Hi my heater is making a click click noise,
Don't worry there is nothing wrong with the water heater making a clicking noise, mines does that too.
Thanks
Jun 03, 2011 | Stiebel Eltron DHC 10-2 Electric Tankless...
No hot water!! For some reason it is not heating the water!?
is the heating element still good. Was it on when no water was running thru it?
Jan 25, 2011 | Stiebel Eltron DHC-E 10 Electric Tankless...
Oct 30, 2010 | Stiebel Eltron DHC 10-2
How do I light my pottertn kingfisher pilot as its gone out? Keep pusing the ignite button but nothing is happening
Push also the gas button and hold in until pilot lit and then for some seconds [8-30] after until the thermocouple is hot enough to tell the boiler to light the main burner
Dec 16, 2009 | Stiebel Eltron DHC Instant Tankless...
Water Heaters Logo
162 people viewed this question
Top Stiebel Eltron Water Heaters Experts
Donni Steen
chargerhp
chargerhp
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
