My remote when pressed does not stop on the channel pick but skipped ten channels like. I press ch10 it jumps up to 18 or so How to stop this
    Top Expert:
  • Televison & ... Master
  • 74,831 Answers
Interrupted infra-red signal from the remote control. Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Posted on Dec 14, 2016
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: http://download.m4c.magnavox.com/files/1/14ms2331_17b/14ms2331_17b_dfu_aen.pdf .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
How do I remove channels ?
Select the channel you want to eliminate, select one by one, and skip them by pressing the skip button on the remote control. Skipped channels will not appear later.
Oct 18, 2014 | Sanyo DP19649 LCD TV
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
Regency R1077 base scanner can not delete old frequencies to reprogram scanner
Press "Manual", then press digit key ("0/10" thru "9") that corresponds with the channel to be changed ("0/10" = ch10). Next, press the digit and decimal point keys to enter the frequency in megahertz (Mhz) to be stored in the channel. To store 453.100 Mhz in channel 2, you would press "Manual", then "2". Press the following keys in order: "4" "5" "3" "." "1" "0" "0", followed by pressing the "Enter" key. Repeat this process for up to 10 channels.If you wish to clear unused channels, you should be able to select the channel, then enter "." followed by the "Enter" key.
This scanner will only accept frequencies between 30.000Mhz and 599.999 Mhz. Attempting to input frequencies outside this range will result in an error message.
I hope this helps and good luck! Please rate my reply. Thanks.
Jul 11, 2011 | Radio Shack Pro-96 Scanner
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
How do you reset the LG DRT389?
to reset hit eject on the machine and the blue text button on the remote for 5 secs
Jun 24, 2010 | LG Cell Phones
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
May 30, 2009 | Hitachi CLU-5713TSI Remote Control
Channels are skipping
Turn the power off to the receiver and let it run its course. It should download a new program guide at this time. Another thing is to make sure you are on ALL SUB on the guide as opposed to a favorite self created guide.Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
