1999 ford ranger won't shift from 2 wd to 4wd it is automatic lock in
Followed owner's manual but won't lock in
    Top Expert:
  • Washing Mach... Master
  • 49,235 Answers
What type wheel locks do you have? manual or automatic . and next time post your question in the correct category or it might get deleted
Posted on Dec 14, 2016
1999 ford ranger won't shift from 2 wd to 4wd it is automatic lock in by a knob turning inside
The shift motor on the transfer case is probably full of mud and dirt and is frozen up. Tap gently with a light hammer, or better to use the end of the handle, while someone moves the selector switch back and forth. Common problem, once it shifts, you can tear it down and clean it, but it is complicated. Probably better to replace it, once you have verified that is the problem.
Dec 14, 2016 | Ford Ranger Cars & Trucks
4 wheel drive lights flashing while I'm driving 97 ford ranger
There's a good chance the electric shift motor is bad. Can you tell if you're in 2-WD or 4-WD? Making a slow, sharp turn will feel different - difficult, clunky - in 4WD.
It's possible to get a manual conversion kit, but that won't solve the light issue, which wouldn't matter at that point, anyway. It could also simply be a wiring problem, with current not getting from Point A to Point B. Checking the OBD II will probably give you several codes, which might help.
I had the electric switching on my Expedition, and it went bad. Not cheap to repair.
Nov 30, 2014 | Ford Ranger Cars & Trucks
I have a 1993 ford f150 4x4 i cant get it out of 4 wheel drive it still drive in 4wd how do i fix this problem
if it has automatic lock in hubs only!! start truck, put truck in neutral, push button for 2x2 shift into reverse,back up 5to 10 feet,truck should shift back into 2x2 automatically. shift into drive and the 4x4 light should go off. if you have manual lock hubs you''ll need to unlock those manually on the 2 front wheels.w/truck in neutral and emergency brake on or someone holdling brake inside truck,go to front and rotate the locking hubs to front tire or wheels in centerof hub to free wheel.they will be marked,or should be. if not,then try turning the center of hub switch counter clockwise until it stops turning,then go to passenger side and turn it counter clockwise. thank you for choosing fixya.
Mar 27, 2011 | 1999 Ford F150 Regular Cab
When I'm in 4 wd the front wheels feel like the brakes are being applied when I make a sharp turn. No problems when driving straight or in 2 wd.
It sounds like you are driving in 4wd drive on dry pavement. The front drive axles do not work like the rear differential. When you turn, the outside front wheel must travel farther than the inside wheel, therefore they are traveling through the turn at different speeds. If you are on dry pavement, this causes the gears to bind. You don't notice this on slick surfaces because the outside wheel will slip instead of bind up the gears. You should not use 4wd on dry pavement. That's the advantage of push button, or shift on the fly, 4wd. You can shift back to 2wd when you encounter dry pavement. All wheel drive vehicles don't have this problem because they have a limited slip front differential as opposed to a locking differential on 4wd. Hope I didn;t confuse you too much.
Dec 21, 2010 | 2004 Ford Ranger
How do I get my 1999 Ford Explorer into 4 wheel drive.
Dec 16, 2010 | 1999 Ford Explorer
Wont disengage out of 4 wheel drive 1998 ford ranger first time its stuck in 4 low we have backed up turned switch numerous times shut it off and restarted
Be sure to put the truck in neutral, while engine is running, while you disengage from 4 wheel drive (low) to 4 wheel drive (high) and then finally to 2 wheel drive. It is critical to shift transmission into neutral when switching out of 4WD Low, as indicated in your owner's manual. Hopefully, this will help to FixYa problem!
Oct 14, 2010 | 1998 Ford Ranger SuperCab
I have a 1999 ford ranger 2 wheel drive automatic
Sometimes this works, ABS light on, check engine light on, speedometer not working, and the automatics start shifting hard or not shifting at all? One bolt and the part is cheap, its weird how one part controls so much.
Mar 10, 2010 | 1999 Ford Ranger SuperCab
4WD seems stuck, RPMs up to 4000 at 35 MPH
There is a motor on the rear of the tranny that switches this. check the plug and it is easy to remove the motor and test its operation. then there is a keyway that you can easily turn with a small blade screwdriver...., Odd but there are no vacuum hoses going to the transmission... OH rats unless it is an automatic... but still the 4WD shifting is electrical..
Jan 04, 2009 | 2003 Ford Ranger Regular Cab
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
