Question about Cooktops
Unlock Ignis hob - Cooktops
How can I unlock the hob
To unlock the hob on your cook top press and hold for about 5
seconds and that should unlock your cook top.
Mar 08, 2017 | Cooktops
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
How do i unlock my neff hob? Red key above on/off switch wont go off! Cant use hob. I also have the red key about the on switch and cannot swithc it on!
hi gud day, more of ceramic hob is touch control,try to stay ur thumbmark wen the unlock circle to unlock if u hear the sound it means is unlock also in the other wat u want to operate,or clean the surface coz some oil is coz of not operate properly. tnx gerbee
May 28, 2009 | Neff 23 in. T4343 Electric Cooktop
Hi I have just had the problem of accidently locking my Neff Hob.
If you hold down the L Lock button for about a minute it unlocks.
Mar 18, 2009 | Neff 23 in. T4343 Electric Cooktop
Hob lock
gud day,the key symbol is the lock try to unlock the unit by touching the sensor,or check the manual how to unlock.
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Indicators
the 'L' means locked - to unlock turn on hob, hold down front right hand side plate control and minus botton to unlock - see manuals for further details
Sep 22, 2008 | Baumatic 23 in. B10 Electric Cooktop
Ignis Gas Hob AKL700
no. not in the uk. a fixed appliance must have a rigid pipe connection with a means of disconnecting/isolating. you must not use a flexible pipe.
pete
Jun 02, 2008 | Cooktops
Cooktops Logo
67 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
