Question about Car Audio & Video
IM TRYING TO FIX AN OLD SHARP 3 CD ROTARY CHANGER THE POWER HAS GONE AN IM SEEKING THE NAME AND CODE OF CHIP TO BE REPLACED IN THE CIRCUIT BOARD,CAN ANYONE HELP THANKS
SOURCE: 2000 Lincoln Town Car Cartier CD Changer
My 2000 town car has a kenwood kcd-512c. but its only playing one track, which is what im looking for a solution to now :)
Posted on Sep 22, 2008
SOURCE: CD's are skipping when playing
Sounds like the laser lens is dirty or out of focus. You can take it apart and try cleaning the lens with a soft cloth and see it that works. If the focus is out of adjustment, that takes alot of patience and time. Never look directly at the laser with the case open. On the bottom or side of the laser lens, there are two small box looking gadgets about 1/4" square with tiny screw type adjusters in the center of them. These are potentiometers, they can develop dirty or burned spots over a period of time. Turning them slightly can give you better performance. If I remember right, one of the pots is for width and the other for height of the laser focus. You can identify them by the small ribbon cables that run to them. Try a very small turn on one and try playing the dvd. Mark with a marker a straight line across the pot and board to know where you started, believe me it helps. This can take quite a while and may or may not work. I find this to be the biggest fault with most dvd and cd players. I have fixed many this way. By the way, I use a jewelers screwdriver. They have small plastic ones for these, but they are hard to come by. Good luck.
Posted on Dec 17, 2008
  • 59 Answers
SOURCE: how do you un-stick a cd from a 3 cd changer
Unscrew the top of the unit and then you should be able to access the cd that is stuck. Then you might have to play with it to get the CD out of the reader.
Posted on May 02, 2009
  • 4970 Answers
SOURCE: Ford Mondeo 2002 6CD auto changer. Error message E 3
According to the Ford Handbook Error Message E3 is "Mechanical Error " and their suggestion is "Install a new Audio Unit "....which is not very helpful
There`s not much that can be done as a D-I-Y solution with these CD Units apart from cleaning the laser lens with a cleaning disk+solution (from your local audio Store or Ebay etc)....or a full reboot ...by disconnecting the unit from the battery for 20 minutes , replacing it and hoping that it will have reset itself.
Make sure you have the correct radio code before attempting this disconnection procedure ( If not, just post the Serial Number (found on a label on the casing) and someone will calculate the correct code.
Posted on Sep 01, 2009
SOURCE: Renault Megane CD changer CD CODE required
i need code for megane II
vehicle code: VF1BM0G0628080003
Posted on Oct 26, 2010
TROUBLESHOOTING MACHINE DOESN'T TURN ON
If the unit fails to turn on, it seems the circuit board has failed. These are sensitive to power surges, or other electrical disturbances. You can have a circuit board replaced, but many times over; the cost is as much or more than a replacement.
Nov 16, 2014 | Nespresso D290/C Espresso & Cappuccino...
White dots appears in my screen. I replace the lamp and the problem is the same. (Sharp xr32x)
I would be willing to bet the DMD chip is failing the cheapest used one i seen was on e-bay the chip # will be something like 1076-6319W the only part of the # that matters is the last from what i have seen they tell me the 6318W and 6319W is suppose to be the same chip the used on i seen on e-bay was $124.00 probably better off seeking a new projector if you can not replace yourself as you will have over half of the cost involved hope this helps Robert
Aug 29, 2012 | Sharp "XR-32X-L DLP Projector"
My model is one pictured on your "Ask a Question".
quick-start guide:
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/
Audio/QuickGuide/Archive/aud_qguide_cddd4500.pdf
operation manual:
Audio/Manuals/Archive/aud_man_cddd4500.pdf
Apr 28, 2011 | Sharp CD-DD4500 System
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
Dec 29, 2009 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
Sharp lc46sb54u will not turn on, I hear clicking inside a couple of times like its trying to turn on. Then power an OCD button blink 3 times over and over. Help!!!
It sounds like you only have the standby 5vdc circuit working, first place to look is the main power supply module, or it can be the main circuit board.
Oct 30, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sharp 42' LC-62C42U main circuit board needs replacement
I would recommend Shopjimmy.com.
Parts are at reasonable prices. Compare with the prices at Partstore.com and you'll see what I mean.
Aug 06, 2009 | Sharp LC-62C42U 42 in. LCD TV
AUDIOBAHN DVD A1451
It would definitely be worth your while to buy the correct cable, try Audiobahn's website for accessories.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 13, 2009 | AudioBahn A1451 10-Disc CD/DVD Changer
I have a Sharp CD-BA2650 3 cd, two tape deck, and radio combo. The Cd turntable sticks when one cd ends and changes to the next. The rotation stops as the motor makes a humming noise, then the lcd says...
There is a belt inside the cd changer that needs to be replaced. Once yo utake the top off the unit you will need to turn the unit on again and open the try. Once it is open look at the back area where the motor is located and you will find it under a circuit board. You need to lift the motor up by pushing the plastic clips that hold the board in place and pull it up a little and you will see how the belt is on the pully. It is very hard to describe how to do this in a forum like this, but if you are careful you should be able to do this.
The part number for the belt is:
92LBE231616
You can get the belt here:
http://www.fox-international.com/
I hope this helps, if so a FixYa! rating would be appreciated. After all, it is the only reward we get for offering people like yourself this free help.
Let me know if I can be of any more help.
Dave
Nov 02, 2008 | Sharp Audio Players & Recorders
Power problem for phillips 42 plasma 42pf7321d/37
That blink don't mean nothing. Measurements need to be made. Don't just buy the board troble shooting would need to be done to see witch board is bad. Also look on the fron of the set and see how many time the led flashes. That wher your error code comes from..
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
