My furnace blowers turn on and then the heat blowers will blow fire into the furnace for about 5-10 seconds, then turn off and the blower will continue about another 5 seconds and the cycle repeats.
  • Heating & Co... Master
  • 3,047 Answers
Hello Sharon Witherspoon,
No ake or model came thru w/question...(?).
At some point your heater will attempt... via a heat sensor, that the FLAME IS ACTUALLY ON...
These are varied configurations..
As it fails to "sense" the heat it will shut off...
and recycle
(I believe this should only repeat a VERY FEW TIMES... so as to not cause an EXTREME DANGER to the user.
On old style heaters this is done by a "THERMOCOUPLE"
I have every confidence ... if you check the OWNERS MANUAL
you will find the trouble shooting.. will point you in this direction...
Make & model.. and search for you paper on the internet
if you do not have your original papers.
hope this helps.
Posted on Dec 14, 2016
When turn on my fire place heater heats for about 5 sec. Then a little white light flash's it turns the in heat colls off blower never turns on
How to Fix a Gas Furnace: Furnace Blower Does Not Turn ...
? 2:51
Jan 18, 2012 - Uploaded by
If the blower in your gas furnace won't turn off, it can cause major problems with your home heating system ...
Electric furnace blower motor doesn't turn on once in a while ... > Forums > HVAC Heating & Cooling
Mar 7, 2014 - 16 posts - ‎5 authors Hi everyone, I'm having a problem with my Broan Electric furnace lately. Sometimes the blower motor doesn't want to switch on. Sometimes it ...
Oct 24, 2015 | Heating & Cooling
I have a CCA24FCC that keeps shutting the furnace off for lack of air flow. The blower seems o be working well, i have replaced the filter even when it appears to be clean. Is there a sensor that measures...
There are 2 blowers to be concerned with. The main blower simply passes the household air over the heat exchanger to provide warm air for the supply vents. The other blower, which is more important, is the draft inducer blower. This is a smaller blower that starts first to create a negative pressure in the fire box to ensure that carbon monoxide gases will pass up the flue when the gas jets ignite. There is a pressure switch associated with this blower. When the inducer blower starts, it pulls air up thru the flue until the pressure switch activates. Then the gas jets can ignite, warming the heat exchanger. A few seconds later, the main blower will start to warm the air. If the inducer blower or the pressure switch is faulty, the furnace will not fire up.
Feb 24, 2015 | Filter Heating & Cooling
Sometimes my Heil furnace combustible air blower comes on and just keeps blowing and the burner never fires up, nor does the heated air blower come on. If I turn the furnace power switch off for 5 or 10...
Flame sencer you can clean it for now but will have to be replaced it located on the opposite side of the igniter it has one wire pluged in to it 1/4 inch screw just wipe it with your fingers and put it back in
Mar 01, 2013 | Heating & Cooling
I turn on my furnace and the coil warms up and then the igniter comes on producing flame but only for about two seconds and then it goes out and the furnace just winds up blowing out cold air, after about...
It sounds like your blower motor is not firing up for some reason. This could be a circuit board issue or simply a dead blower motor. What is happening is that the system is basically sensing that the heat is not being "blown" to the rest of the house and it shuts it self off to prevent damage. After the flame comes on you should hear another motor come on. Also, most furnace's have whats called an error led that will blink when the system shuts off. Each blink represents a different error. You will probably get something about high heat limit reached.
Mar 01, 2011 | Heating & Cooling
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like that i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
I have a goodman mfg gmp100-4 furnace. When I turn theromsat to heat I hear blowing for sixty seconds but that is all that happens. What should I check first?
Your furnace has a combustion blower on it. If it runs and don't pull in the vacuum switch the furnace will not start. On the combustion blower you will find a little rubber hose follow that hose to the vacuum switch. You will see 2 wires on the vacuum switch connect the 2 wires on the vacuum switch together. If your furnace starts and runs fine for 15 to 20 minutes you need a new vacuum switch. Try this first
in this image A is vacuum switch B is combustion blower
Hope this helps......
Nov 16, 2010 | Goodman Heating & Cooling
Carrier Furnace infinity 96.model 58MVP060-F-18114. Furnace heats
Sounds like it could be your fan limit switch. Part costs about 20 bucks and is fairly simple to replace. This limit switch is a safety that prevents your furnace from over heating. Usually when your t/s is satisfied the blower runs for a little longer after the burners have stopped, and the reason for that is the limit switch. The blower is supposed to cool this limit switch to a certain temp. and once it reaches this temp it shuts the blower off. Yours is stuck:(
Feb 13, 2010 | Heating & Cooling
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Furnace runs but won't ignite.
Error code 12 is blower on after power up. Meaning: after you turn on power to the furnace for aprox. 60-90 seconds the blower will run. The blower should then shut down and the furnace should go through the start up process, providing that the thermostat is set for and calling for heat. If the furnace fails to start after blower shut down there should be a new fault/error code. However if the blower continues to run longer then 90 seconds and continues with the same fault code more then likely the circuit board is bad. Please let me know if this was helpful and give me a rating. Good luck.
Feb 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
