Question about Brother Office Equipment & Supplies
Brother hl 2130 paper stucking - Brother Office Equipment & Supplies
SOURCE: Paper jam in Brother HL-2140 printer
I have the same problem - try what it says at this link.
Posted on Mar 18, 2009
  • 83 Answers
SOURCE: I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Posted on Nov 13, 2009
  • 622 Answers
SOURCE: black lines down side of paper on HL-5370 brother laser printer
you have a bad drum... it needs to be replaced
Posted on Dec 27, 2009
  • 4737 Answers
SOURCE: I amusing a Brother HL-2140. Recently, the paper
Turn off the machine, > Open the front cover > remove the drum, cartridges, > and check if you can see the jammed paper or not, if so pull it out slowly. If you can't see the paper, close the front cover > Pull out the Tray completely > and once again check if you can see it or not, if so pull it out. Still it's not there? then install the tray and open the back door > pull the tab to open the fuser unit and pull out the paper, you can also pull out the fuser unit.
You can also refer to this tutorial from Brother Solution to clear paper jam
Good luck.
Thanks for using FixYa.
Posted on Aug 13, 2010
  • 270 Answers
SOURCE: my lamp "paper" blinkikg brother hl-2030
Remove the Toner Drum unit and look for a little blue tab. Slide it back and forth a couple of times to clean a corona wire and see if that helps.If the problem still exists, you may try this 2nd option.
> the front door. There is something wrong with the front door, or the mechanisms that signal that it is closed. Closing the front door (the one that you open to pull out the toner and drum) all the way to where it snaps into place then the paper light flashes red. However closing the front door to the point where the "ready" light comes on (don't snap the door into place, just close it and let it rest in place without snapping it closed) and the printer prints fine, pulls paper from the tray and prints like it should.
So give it a try, don't snap the front door all the way closed to where it snaps closed, just close the door to where it's resting closed to where the ready light comes on and see if this helps you.
Posted on Nov 20, 2010
How to print both side in hl-2130
Hi there.
The HL-2130 does not have an auto-duplexing system included in the machine. If you wish to duplex print you need to print the first page then feed that page through the Manual Feed system (Side to be printed up, top of page first) and print the second page on the manually fed page.
Aug 17, 2014 | Brother HL-2130 monochrome laser printer...
How do I print from my Samsung Galaxy Pocket S5300 to a Brothers Printer HL- 2130
hL-2130 is not a wireless or network printer. So it is unlikely you will be able to print directly from the S5300 even if you get a Samsung wi-fi print app. You can however, try to use services like Printer share which can allow you to configure your computer connected to the printer to be used as a printer client to service wi-fi printing from your mobile phone.
Apr 27, 2014 | Samsung Galaxy Cell Phones
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
I have a brother HL-2130, the toner light came on and the printer doesn't want to print anymore, even after i have replaced the toner with a new one. Can anyone give me some advice please?
This WEB site shows how to reset your printer after install a new toner.
Apr 03, 2012 | Brother HL Office Equipment & Supplies
Hi we have a HL-2130 it has just jammed with
when you say "will not work" is this means the unit is dead set no power?or theres an error code what is it?
Sep 11, 2011 | Brother HL-2040 Laser Printer
Good luck,
Nov 13, 2009 | Brother HL-2040 Laser Printer
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
26 people viewed this question
James Cagle
James Cagle
Jim Keysor
