Question about Microwave Ovens
The "oven" light comes on when trying to use the microwave of our 5 year old G E Advantium 120. It worked just fine 20 minutes earlier. Now the oven comes on with any buttoned pushed.
    Top Expert:
  • Microwave Ovens Master
  • 52,123 Answers
It turned out to be the door safety switch on mine a couple years back
Posted on Dec 14, 2016
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
Advantium display reads "nite"
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 30, 2017 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Advantium 120 model # SCA1001HSS03 has died and working. The circuit breakers is fine. The dedicated electrical line is working fine. There are no lights, no sign of life. The oven was working and at the...
Many microwave ovens have an internal fuse , but I was recently told by a dealer that any unit costing under 200.00 was not worth fixing .my fuse cost 3.15 from local home improvement store
Oct 19, 2017 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Hello, I have a 7 year old GE Advantium oven that the microwave has quit working on. The power and timer come on but the actually cooking element of the microwave is not working. When testing the oven...
I would first suspect the primary interlock (top door switch) or maybe that switch's mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
We have the service manual and have uploaded it here to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Aug 19, 2010 | GE Advantium 120 Convection/Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
