Question about Radio Communications
Hi my midland78 plus multi cb radio will not change from uk am to U.K. Fm which is where it needs to be
  • 150 Answers
SOURCE: cb radio
Not without some serious board modification.
Posted on Sep 15, 2007
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: setting 3300 to basic cb oper.
On the 3300hp use band switch at position A band switch to hi
Posted on Jan 25, 2008
  • 3051 Answers
SOURCE: With my CB I am getting feedback through the am fm radio speakers
Hello there:
the shielded coax rgu-45 series is probably the best one for this application also if you run the radio to a different fuse or u can also get a surpression filter that goes on the coax line I own a WL9000 KW. i had the same problem untill i got the filter installed at a loves truck stop in texas and no more problems since ok?
drive safe and best regards mike (warner transp.)
Posted on Aug 17, 2009
  • 773 Answers
SOURCE: please explain a 10 meter am/fm radio
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Posted on Dec 09, 2009
Midland 78 multi
next to the positive and negitive wires inside the radio is a zenner diode .check to see if its burnt.If it is replace it. and your radio should start.
Apr 10, 2014 | Radio Communications
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
Midland 75 785 purchase from us will it work on uk channels
  • For 11 meter (CB) the standard 40 channels will be the exactly same as the "EU" set of frequencies (channels). However the "UK" 11 meter (40 channels) and the U.S.A. 40 11 meter (40channels CB) will not work together at all. This includes any actual Citizen Band radio, excluding Export 10 an 12 meter radios often labeled as "CB'S" which they are not.
  • Hope this helps.
Oct 29, 2011 | Midland 75-785 Handheld CB Radio
Cobra 19 DX IV, I bought this unit in america, but i live in the U.K. and can't pick up any channels, does this unit Only work in america, can i get somthing for it to work in england??? Thanks...
  • The UK uses more FM frequencies than AM frequencies. So the CB will work over there just fine but you will need to find someone who uses them frequencies as well or it may no be much fun. Here is a frequency chart for what we in America call import radios shipped from over there. 27.555 FM is the main frequency used in the UK but the Cobra 19 is a strictly AM CB. Also on the link on the far right are the standard 40 channel frequencies from the UK version of CB's and not one is the same as the Cobra 19 as the UK uses FM for their 40 channel CB radios.
  • Here is the 40 channel CB frequency chart utilized in America
  • Hope this clarifies things for you.
Regards, Tony
May 18, 2011 | Cobra 19 DX IV CB Radio
My alan 48 plus cb dont seem to change to uk how do u change this thanks
the first button on the right hand side changes the fm to am but these usually break down. it is a small push button switch with four legs two at each side, but recomend sending it in for repair.
Aug 17, 2010 | Midland 1001Z 40-Channels Base CB Radio
Midland alan 42 multi CB Radio
The user manual can be found in PDF form here:
Feb 26, 2010 | Midland Radio Communications
FM conversion ?..
Speak to Spectrum Communication, they sell FM boards. Google their company name for details. thanks
Jun 22, 2009 | Uniden PC78ELITE 40-Channels Base CB Radio
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
You would have to replace several components on the board(requires alot of soldering and the parts needed are a little hard to come by) in order to change the output frequency ranges. It is alot of work to do this and is probably not worth all the work, Best advice I can give you is to replace it with an AM one and sell it.
Hope this helps
Sep 11, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
54 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
