Question about Kitchen Ranges
Code-fc- what does it mean? - Kitchen Ranges
If keypad displays the FC code Can you still program a new master code?
I have never tried that because it has never been requested. "FC" is a higher priority. It means failure to communicate. So I would always correct that problem first and then change the master code. But I don't see why you would not be able to change the master code due to FC code. Gl.
Jan 31, 2015 | Honeywell Ademco Vista 20p And 6150 Keypad...
Trying to change master code on 6150 vista 20
Either you are locked out of installer programming or you do not have a Vista 20...this sounds more like a larger panel such as a Vista 40, 50, or some other 4140 based system...verify the model number by opening the main cabinet. The inside cover should have a diagram of the system and the model number. However, since the boards are easily replaced, the cover label is not always accurate. Look at any labels on the printed circuit board to help you properly id the model. By the way, FC indicates Failure to Communicate, meaning the unit tried to call the monitoring center but could not get through (usually 10 attempts) and is unrelated to the "master code". Hope this helps.
Jan 31, 2015 | Honeywell Ademco Alarm Vista 20p 6150...
Remove FC code Ademco Vista 15P alarm sysem
FC means failure to communicate, call your monitoring company to test your systems communication. If your system uses or used your phone line call on a cell phone so you don't get cut off when you system tries to call to monitoring company. gl
Jun 05, 2014 | Honeywell Ademco Vista 20p And 6150 Keypad...
Beeps and flashes FC
The "FC" error code means "Communication error between boards".
Check the "J2" harness, ohm wires end to end.
If the harness is fine then the display board is defective.
Here is the part to order.
Jan 24, 2013 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Honeywell vista 20p FC error code no monitor service beeping every 30 sec. need help how to stop beeping
If the keypad displays FC, that means that it is programmed to send alarms to a central station and a phone line isn't connected to the control panel. If you do not subscribe to monitoring services, it will have to be re-programmed. I can do that for you over the telephone if needed.
Thanx Mark Garrett
Aug 21, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
There is a flashing error code on my keypad - FC. What does this mean? I had a service tech in to repair this problem and he said it was solved. No sooner did he leave and the "FC" began...
If you are not monitored, the FC will come up every time it tries to send a signal to a monitoring station. FC means 'Fail To Communicate" Contact me if you need further assitance
Jul 15, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
J SP420 NIBB GE oven Display reads FC locked door and oven will not work but stovetop works.
The "FC" error code means that there is a failure in the door lock circuit.
You may want to check the switches in the door latch first. Then check the wire harness from the door latch to the control board. If there is nothing wrong, replace the control board.
You may need to get an appliance repair person out.
Mar 18, 2011 | GE Ovens
Hisense air conditioning unit displaying FC, what does this mean?
FC Outdoor low pressure drop. Check your gas pressure. It should be 60 PSI in ambient temp of 98 degree Fahrenheit.
Less gas pressure not only due to gas leak. But also indoor coil and air filter chocked . Service the unit and test again. Helpful?
Jan 02, 2011 | Heating & Cooling
It keeps beeping and shows code FC in the window
hi FC is communication error between boards what that means is wiring harness or power relay board(prb)
Oct 15, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
