My readings are suddenly very high.Could it be monitor malfuncyion?
How to calibrate my Jobar blood pressure cuff?
Was yous at heart height when you took readings? Too low will give high readings. Nibp can differentiate by as much as 10-15% remember.
Sep 05, 2014 | Health & Beauty
My Omron blood pressure monitor does not give me a correct reading. It is about 20 point higher than is should be when compared with a professional monitor. Can my monitor be re-calibrated to read the...
BEFORE TAKING THE READING DONT USE IT BEFORE COMING UP FROM STEPS OR SUDDENLY WALKING AND TAKING READING
IF YOU TAKE READING IT WILL COME HAZARDIOUS
SIMPLY RELAX FOR 10 MINUTES AND STAY CALM WITHOUT TALKING
AND FOLLOW AS PER MANUALS TO TAKE READING
Sep 10, 2011 | Omron Automatic Blood Pressure Monitor w/...
Why does my asus monitor always read "no signal".
nah that happens with me sometimes..
have you connect the cable properly?
if that still can't make it works, first turn on your PC and monitor..
then plug off the cable that power them, so that your computer and monitor will suddenly off..
plug it on again, then your monitor will work again..
that works on mine cause my CPU is too old and had a power problem..
May 07, 2011 | ASUS LCD Monitor
How to change my display setting when my monitor sudden stops working at 1076x768 high resolution
uhh it obiously cant take that resolution maby it can try install a new driver if that does work sorry it can take that high of a resolution
Jan 12, 2011 | LG Studioworks 552V 15" CRT Monitor
The systolic pressure reads high in comparison to other monitors and physicians readings.
After working in the healthcare field for a while, I never trust automatic blood pressure cuffs or machines. They usually always give a high reading, I usually check with a manual reading after getting a high reading from a automatic reading.
Dec 30, 2010 | Health & Beauty
My Omron 711 seems to register readings that are too high when compared to doctor's office or monitors in drug stores, etc. Is there a way to check accuracy of the monitor?
Take the cuff to your doctors office and have the nurse check with yours and the office BP cuff. If your cuff is too small, you will get a false high reading.
Nov 30, 2010 | Omron HEM-711 IntelliSense Automatic Blood...
Monitor keeps going blank - when im on internet it will suddenly go extra bright for a half second, the blank. if I switch it off using the button on the side and switch it on again, it just goes blank...
loricaney, Do some research first. Go here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ I just read a comment that some guy wrote. He stated that he aquired 30 Vs17 non-working units from a high school, and that 25 of them had bad (swollen or leaky) filter capacitors. The other 5 had cracked lcd panels. maybe $6 in new capacitors will restore unit for you. Do some reading in my fixya profile and "budmrtn" and "buddymc" fixya profiles. let me know if you want to do a DIY repair after you do research and visit YOUTUBE for video clips of owners doing typical capacitor removal and installation. 12fixlouie
Aug 09, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Oil pressure really high
get the oil pressure sender and gauge checked most likley cause is incorrect reading not sudden high oil pressure
Oct 22, 2009 | 1991 GMC Sierra
Reading are much too high, normal BP is 104/50, monitor reads 130/60
if your arm is too large for the cuff it will read high. most cuffs are made for small framed people. try wrapping it around your lower arm and postion it about 2-3 inches above the wrist. use the wrist to take the b.p.
Jul 27, 2009 | 3M Mabis Adult Aneroid Blood Pressure...
Computers & Internet Logo
David Payne
David Payne
