Question about Refrigerators
Sub zero particles in ice from ice maker
Sub zero side by side. There are particles in ice from the ice maker. What is it and how do I fix it?
  • 315 Answers
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
    Clean the Ice Machine
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
    Reassemble the Ice Maker
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Posted on Jul 20, 2009
    • mithun dey
      mithun dey Jul 20, 2009
      If I have fully answered your question, please click on fixya and feel free to ask any follow-up questions you may have.
    Ice maker stopped making ice
    If ice maker is not filling with water then fill with tap water and allow to freeze. If ice maker cycles and then does not refill then this points to water control valve. If that happens replace water control valve. Ifice maker does nothing but freeze water to ice then the ice maker will need replaced or parts causing problem fixed. Please call Sub Zero at 1-800-222-7820 and they will refer you to one of their six authorized parts and service centers. Thank You, Sea Breeze
    Nov 24, 2011 | Sub-Zero 690 Side by Side Refrigerator
    Ice maker stopped
    Hello, this video explains how to repair a Sub Zero Ice Maker.
    You can also find more Sub Zero Repair Help at Appliancerepairlesson.com
    Feb 26, 2011 | Sub-Zero 690 Side by Side Refrigerator
    I have sub-zero model 3211 red. My ice maker stop making ice. what to i do?
    Here is a link to a Sub Zero Repair Video
    http://www.appliancerepairlesson.com/shop/refrigerator/sub-zero-diy-repair-video-for-replacing-ice-maker/
    Feb 20, 2011 | Sub-Zero Refrigerators
    Ice maker is no longer making ice help!
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    Oct 06, 2010 | Sub-Zero PRO 48 Side by Side Refrigerator
    The ice-cube maker on our Sub-Zero 650 has stopped making ice.
    try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
    Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
    Ice maker made too much ice, then none at all...
    buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
    Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
    Ice maker does not work in the sub zero 690
    The fan seemed to not work when we closed the door so we taped the button to keep the fan running,
    May 16, 2009 | Sub-Zero 690 Side by Side Refrigerator
    Sub zero 690 ice maker
    also discovered if ice box auger not engaged exactly right with auger drive motor, then ice box won't be able to be pushed back the last half inch to engage the secret "turn on the ice maker" switches. Juice storage brackets also won't engage since ice bucket not flush with front of cover.
    Jul 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
    ICE MAKER SUB ZERO REFIGERATOR
    Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
    Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
    Water/Ice Dispenser Does Not Consistently Work
    Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
    Thanks for your help as it fixed my problem as well, albeit temporarily.
    Alan
    Jan 12, 2008 | Sub-Zero 695/O Side by Side Refrigerator
    Refrigerators Logo
    379 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
