Question about Canon PIXMA MP510 All-In-One InkJet Printer
Jammed paper paper wont feed through the printer
  • mcdish Nov 22, 2007
    I seem to have this same problem. I just changed the black ink cartridge and since then the printer claims that the paper is jammed ( which it isn't!) I cannot clear it and even pressing OK on the printer doesn't get rid of the message. Turning the printer on and off doesn't help either. There is no paper jammed in the printer!
one day I had similar problem. Just after changing black catridge, printer shows me jammed messeage.
I was almost crazy!! of course there's no paper jam!!
However, ... I found 1 big roache.. .. deep in the printer..
after remove that with thick paper, jam meesage has gone.
So, I suggest you do the everything in manual you can do when the message come up, if not solved, use thick paper such as broshure..(right?) and put it strongly into the paper tray.
good luck.
Posted on Dec 28, 2007
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Documents wont feed
If not using track feed paper this printer should have a setting for paper height. If its set too high the
rollers wont grab the paper. Also look for any paper that might be jammed or caught up in any of
the roller mechanics.
May 09, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Pinter iP2600 says I have a paper jam and wont feed paper. I see no paper jam but paper wont feed.
perhaps if you got a paper when you try to remove jammed paper to a piece of paper rupr remained on paper route, and have seen where, if paper was not broken when it is possible that when you pulled a paper to be skipped sensor that never returns to the starting position
Apr 12, 2011 | Canon Office Equipment & Supplies
Paper wont feed in anymore. Tries to feed in but goes in wonky and then jams
Check to see if there are any jams in the printer, use a flashlight to get a good look around.
If you don't see any jams, Shake the printer around to loosen up any debris so it falls out of the printer. Alot of times kids fool around and put things in the printer and sometimes they are in the area where the paper feeds thru. If you do this and the paper still jams up, then that means the gears are worn and you'll have to get another printer because parts wouldn't be available for it.
Apr 19, 2010 | Lexmark X3480 All-In-One Printer
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Canon Stylus C64 paper jam
try this link below. Although the printer is lexmark but it can used the idea to solve the problem regarding paper jam issue.
Jul 31, 2009 | Epson Stylus C64 InkJet Printer
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Problems with paper feeder-wont feed through-chews up paper
Jan 31, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Paper fed
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
193 people viewed this question
old marine
old marine
