Question about Ski-Doo 2007 Skandic SUV 550F
My 2007 550 skandic wide track with the manuel gear box when in the forward gear the engine idels down and then the motor goes backwards sounds like a electrical problem
MY FRONT DRIVER SEAT ON MY TOYOTA SIENNA 2004 HAS BEEN GIVING TROUBLE MOVING BACKWARDS AND FORWARD, NOW STOPPPED MOVING BACK AND FRONT COMPLETELY. MOVES UP AND DOWN. NEED TO MOVE FORWARD TO REACH TO D
Not an easy fix, plastic gears either wear out or get clogged over the years with dirt and lint. Whole motor assembly and track cost around $300 new.
Oct 14, 2014 | 2004 Toyota Sienna
Why won't 2002 maxima seat go forward or backward? Can hear the motor and nothing stuck on track
I would say the cables or rods that go from the motor to the gears are broke or stripped.
Aug 08, 2012 | 2002 Nissan Maxima
How to change front power seat track worm in 1993 landcruiser
Lift the front edge of the seat bottom by using the regular power seat switch. Take voltage readings of the seat slide motor.2 Verify that the voltage to the seat slide motor on the harness side between "BR" and "W/B" is 12v when the power seat's switch is pressed backwards and forwards. Jot down your radio presets and tap the seat slide motor so that the motor will work long enough to give you access to the seat mounting bolts.3 Pull the seat as forward as it will go. Take off the two M10 rear seat mounting bolts and set them aside. Push the seat as far back as it will go. Take off the two M10 front seat mounting bolts. Switch the ignition so that it marks "OFF." Unplug the negative battery cable. Stand by for 4 minutes. Raise the seat assembly to find the harness-to-seat connectors. Disconnect them.4 Take out the entire seat assembly and place it on a dry, clean, flat surface. Position it so you can access the bottom of the seat. Undo the seat bottom's carpet flap and take out the four M8 bolts. Then, take out the top screws from the right hand and left hand side finishers. Unplug the seat sub-harness connector.5 Put both the seat rails back into their rear position and take out the worm gears, motor, flexible wire and gear boxes all at the same time. Take out the flexible wire from the gear boxes using a screwdriver. Verify that the new seat track mounting tab makes contact with the rear stopper and that the threaded shaft facing up is point upwards. 6 Install six new rubber grommets. Place the new worm gears, flexible wire and gear boxes into the frame. Reposition the seat tracks over the seat track mounting tabs. Use your hand to tighten the M6 bolts securing the seat track mounting tabs. Torque the six base plate nuts securing the gear boxes to 64 to 85 inch pounds (7.17 to 9.69 Nm) and the M8 bolts on the seat's front edge to 13 to 17 foot pounds (17.5 to 23.7 Nm).7 Plug the slide motor connector back in and hook the carpet flap's strap. Reinstall the seat assembly and reconnect the electrical connectors and negative battery cable. Torque the mounting bolts to 27 to 36 foot pounds (37 to 49 Nm). Operate the seat to make sure that the problem has been resolved
Sep 29, 2011 | 1993 Toyota Land Cruiser
I have a 1995 Dodge 2500 pickup and the drivers power seat won't move forward or back. It seems to be jammed somewhere on the track. The motor is working and the drive shaft is turning. The seat starts to...
Check for any kind of obstructions in the track. If there is nothing there, you can try to have someone push the bottom of the back of the seat while you push the forward button, and vice versa. Sometimes the rails get stuck from debris or something wedged in the track. The only other thing I can think of is to take the seat out, remove the drive shaft and try to knock the track free with a hammer.
Oct 25, 2009 | 1995 Dodge Ram 2500
Battery keeps a charge I have to push the scooter in gear and then it works
ok, that sounds like a load problem
check the motor brushes also it could be the speed pot has a intermittent connection, try moving it up and down as well as forward or backwards, it if bites while moving it up or down you need to replace the speedpot or wigwam as some people call it.
Make sure the connection between the batteries leading to the motor controller, normally a box or grey box are good, check the M+ M- lead connection the motor controller.
Regards
GeWiz.
Oct 10, 2009 | Zoom 220 HMV 3-Wheel Travel Scooter
2002 Chev Impala - Passenger Power Seat
The gear our rotating cable is stripped
Jul 23, 2009 | 2003 Chevrolet Impala
Driver's seat unable to move forward or backward
There are plastic gears connecting the track to the seat assembly. Whne one of these strip the seat will only work or move to one side. Infiniti does not sell a simple fix. You are looking at buying an entire seat assembly complete with the module for all the electronics. It will be at a cost of around $950 - $1000. Once that is in, Infiniti must program the seat to the brain of the car, only then can you reset your memory settings.
May 19, 2009 | 2004 Infiniti G35 Sport Coupe
Power drivers seat does not move forward and backward
if thare is a clicking sound heard then the fuse is not blown so this means ether the seat motor or transmission has gone bad and you half to replace the hole seat track, cause i dont think servisable parts are available for this vehicle
May 03, 2009 | 2003 Mercury Sable
97 Grand Prix sunroof off track
My 97 Grand Prix sunroof tracks are offset. My driver side track is in the closed position, and the passenger side track is in a half open position. When the problem happened I was closing the roof and heard a hard clicking. It stopped working from that moment on. The tracks werent offset as much as they are now before I took the glass off. When I removed the glass, the passenger side track sprung back about 6 inches. The motor works, but the tracks only move about a half inch forward and backwards. Its cable operated and my guess is that one side jumped the track or a gear or something. Anybody help?
Apr 10, 2009 | 1997 Pontiac Grand Prix
Ski-Doo 2007 Skandic SUV 550F Logo
112 people viewed this question
Top Ski-Doo Winter Sports Experts
ptpumpman
David Harrelson
David Harrelson
Noel Bennett
Level 1 Expert
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
